Ring gap question
beast02er
I'll add another note to my "shade-tree" method. I purchased a ring file because I thought I would have to adjust the Goetz rings to fit the individual bores, but I must have been pretty lucky, because I didn't have to use it.
I feel the same way about the hacksaw, chisel, pry bar and 3 lb hammer I keep in the trunk! If the trunk were bigger, I might say the same thing about my torches too.
Tools that lucky people dont need:
Hmm.....
Almost every motor I have built (mot like there are more than 15 in my history) have used new pistons and rings and a fresh bore. Maybe its because of the quality of the replacement parts used..... Who knows. When I was a kid building my first A series motor I re-used the stock pistons and used iron rings in old sloppy bores. Worked fine for a little while.
I always check em. You guys should have seen me installing the J&E pistons in my current motor.
John
1665778
  • 14 years later...
My little bit. A brand new factory block, the bore has a taper to the bottom, this is why you see a ring gap measurement from the bottom. once the cylinder has been bored this takes the taper out and is now close to a perfect tube. Now you can take the measurement from the top if you like. I like using cast-iron rings, as the gapping tolerance is the same from vehicle to vehicle measured From bore size.  however original M10 gaps are quite large I suppose that is the composition of the ring material.
How does one bore a tapered hole?
Maybe OT means they wear in a taper.  My experience has been more that they wear somewhat egg- shaped,
with a belly in the middle.  But honestly, I've never bothered to map it carefully...
One does wonder why a 15 year thread was bumped...
I'm working on a couple of M54s right now- 200k miles, and almost no wear.  TONS of build- up, but
even the ring flank clearance is well within spec.
M10s wear out quickly.
New User probably a Bot or AI
Edited by uai
I do find myself wondering what the BotAIPseudoIntelligentsia is learning- maybe it's
modelling our behaviour to better simulate us when it takes over the world...
tapered
AI will as stupid as humans it tries to simulate. When wetware gone nothing changes.
bored
Edited by tzei
