G (nt)
cj
  • Replies 176
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Wheels are something I don't know that much about. Will these fit on stock cars? Any expected rubbing issues?
So they are 15" by 7" with 25mm offset?
I'm not 100% clear but I really like'em and I'd be interested in 8 or 10 (two full sets) possibly.
thomasjwinston at yahoo dot com
E36
Perfect size for a stock 2002.
Charlie Mac in Sacramento.
My Blog
I'm an كافر
With the 25mm offset, I've found that this is optimal with no clearence issues. KEEP IN MIND ALL CARS ARE DIFFRENT. I fit them on Armonds car with no issues using a 195/50R15 tire on the car in the initial post. His car also has the fixed camber plates with Eibach springs and Bilstein dampers.
Cris
Proud member #113
The rides!
www.cardomain.com/ride/792851
www.cardomain.com/ride/792793
Cris,
I'm curious, how wide is that lip on the wheel?
The lip on the 30mm offset is 1.5". The 25mm offset wheel at MINIMUM will be 1.5".
Cris
Proud member #113
The rides!
My car has turbo flares.Any chance you can order some sets with correct width and offset for those of us ?
I'll check to see what other offset options I may have. Unfortunatly, even WITH the flares, there will be some clearence issues at lock to lock on the inner fender firewall if we specify a lower offset. You'd need at least a 0 offset to fill the flare.
Cris
Proud member #113
The rides!
