Sign in to follow this
cj
G (nt)
177 posts / 342101 viewsLast Reply
Wheels are something I don't know that much about. Will these fit on stock cars? Any expected rubbing issues?
So they are 15" by 7" with 25mm offset?
I'm not 100% clear but I really like'em and I'd be interested in 8 or 10 (two full sets) possibly.
thomasjwinston at yahoo dot com
Perfect size for a stock 2002.
With the 25mm offset, I've found that this is optimal with no clearence issues. KEEP IN MIND ALL CARS ARE DIFFRENT. I fit them on Armonds car with no issues using a 195/50R15 tire on the car in the initial post. His car also has the fixed camber plates with Eibach springs and Bilstein dampers.
Cris
My car has turbo flares.Any chance you can order some sets with correct width and offset for those of us ?
I'll check to see what other offset options I may have. Unfortunatly, even WITH the flares, there will be some clearence issues at lock to lock on the inner fender firewall if we specify a lower offset. You'd need at least a 0 offset to fill the flare.
Cris
