cooling hose divider, good-bad-junk
Go to solution Solved by John76,
I think John has nailed it. Recycle and reuse. Did that JB hack 20+ years ago and still holding strong. Cost= 5 bucks and 15 minutes total to mix, apply then sand all nicey the next day. Just another part of the old car hobby.
 Bob
71 2002
85 M635
89 327is
98 M3
Quote
Yes- so much this.
Don't get so bogged down in the details that you never finish.
Don't spend so much time and money on it that you're afraid to drive it.
Wisdom. Good Habits.
And as Toby always says, good habits are fun! 🤩
Where we goin’? … I’ll drive…
Side note --  Make sure the flange on the divider that's shared with the intake manifold is the same thickness as the one on the manifold.  Otherwise the thick washer that spans the joint will not clamp them evenly.  You can either shorten the tall one, or put a step on the underside of a washer to make up the difference.
Pic of the thick washer. Don't use a thin one...they tend to leak for some reason.
Don't forget to use the plastic insulating bushings on the fuel pump studs.  They take up the slack in the otherwise sloppy holes; assuring that the push rod is properly aligned.  Part #5.
Fuel supply/pump/filter
No. Description Supp. Qty  From   Up To  Part Number Price   Notes
01 Push rod KFST. PUMPE 1     13311250398 $12.93
02 Insulator AF 1     11111721614 $6.77
03 Set circlip 10 4,0 2     07509064292     ENDED
04 Pin   1     13310075773 $3.60   ENDED
05 Insulating bushing   2     13310075752 $1.57
Yes, I know mine are missing.
I ordered these from Autohaus AZ last year, but only received 1 bushing. Web site says only 1 /car, so I assumed (wrong) that you get two bushings per pack.
It's on my "to do" list ... along with getting my engine put back together!
On 4/18/2024 at 5:33 AM, FL7602 said:
Tech71, if you have a good used spare message me please.
Yeah, my bad sorry. I have only located a couple as in 2, but need to hang on to both.
76 2002 Survivor
71 2002 Franzi
85 318i  Doris
