Sanity Check - Oil Pump Chain Tension
JsnPpp
I pulled the pan, removed the nut and measured. 7.9mm
The washer is in place and the gear is straight.
Thread depth is 7.3mm. So, good catch on this that it's 0.6mm wider than the threads.
 I do like the thinner nut listed. I did check and 07119901301 appears to be available, part 18.
I don't see where 07129922436 is listed as a replacement but it is a locknut.
SO, long/short. I don't mind waiting another week if I choose to orderf the nut but I'm trying to decide if it would make a difference. Slightly wider + red loctite is the same to my mind as slightly thinner + red loctite.
Is it agreed that 45NM (~35 ft-lbs). Does this feel ok to the group?
As a data point, here is the pump before I pulled it and a movie for the original slack. It's the same nut that ran for 12 years + 60K miles. Not saying that makes it ok but it's a data point.
https://youtube.com/shorts/-3hXdzUPP2c?feature=share
Edited by JsnPpp
1973 2002tii (2764167), Baikal, sunroof, A/C, 5spd OD, 3.91 LSD, etc. Rebuild blog here!
--> Blog: Repro tii cold start relay;   --> If you need an Alpina A4 tuning manual, PM me!
I think you are good to go with that nut, it looks like the OE one, sorry, it looked to fat in the first pic.
Might as well use red locktite this time😁
76 2002 Survivor
71 2002 Franzi
85 318i  Doris
No sorries needed! I asked for sanity check and appreciate the time you spent on this. I don't love redoing things but I'm used to it, ha ha. Better to be safe and double check, it's 100K times easier to fix now than when the motor is back in the car. I'll switch to red loctite.
The youtube link wouldn't embed for me last night for whatever reason.
I'm going to use ~35 ft lbs. Here is the best link I can find on this topic:
Since that nut didn't exist on the car during (or even for decades after) its manufacture, there won't be an
original torque for it.  I don't remember when it eventually showed up- E36 era, maybe?
One of the dumber- of many- BMW cost- saving measures.
If I was a person who regularly used a torque wrench, I'd find the earliest stated BMW torque
and use that.  35 ft- lbs seems to be in the right ballpark.
still uses blue loctite, but
also uses sleeve retainer.
Thanks folks. I did switch to red loctite and squeaked it up to 40 ft lbs torque.
Jason
Jason
Perhaps worth noting (on the late side, perhaps) that not all “red loctite” is the same… for example, some types  of red loctite are suggested (rated?) for combination of heat + oil resistance, others, not-so-much. -KB
Appreciate that, good call. I used Permatex Red 27100 which described as heat and vibration resistent + is permanent (may require special tools).
Says it's good for rocker arm studs, etc. transmissions...
I'm actually now more concerned if I ever have to get the dang thing off!
It feels like it's ok, but if anyone has had bad experience with 27100 then please let me know..
Jason
