1969 BMW 1602 won’t idle
rtgorham
Go to solution Solved by rtgorham,
Hi, all of a sudden yesterday the car kept stalling every time I take my foot off the gas, like when slowing for a stop light, and it won’t idle. The L warning light goes on each time it stalls. It starts up again each time with no problem. I’ve been told The points are worn. Could that be the problem? I’m new to this forum and not a lot of mechanical knowledge. Thank!
  Bet it's a plugged idle jet
  Remove, blow it and its orifice out with carb cleaner and reinstall.
To check for idle jet solenoid operation, turn on the ignition, then disconnect the wire.  You should hear a click.  No click = no idle.
  • Solution
Happy to report I was able to figure it out. The throttle connection to the carb was really loose. The throttle adjustment screw wasn’t even touching the prong. It was obviously not tightened up properly months ago when I had some work done it because I noticed then that the choke wasn’t as effective afterwards, but the car was running much better overall so I didn’t pay much attention. It must have finally loosened up enough over time that it began stalling. Something so simple.  Thanks again for all the feedback. Pic of our baby.2EAD9577-5ABA-4556-91CA-FEB85C0EB51B.thumb.jpeg.cd13c92e2659e5f2650eb6854f85fd07.jpeg
  • Like 6
