How do I reinstall idler arm bushings???
On 5/18/2017 at 3:34 PM, 72ITB said:
I removed the black insert and used a razor blade to add more taper to the edge of the blue plastic and then tapped them in with a plastic mallet. It did not look like they would fit but this worked.
+1.  I put the blue outer shell in first then tapped the inner black bushing.
That torque specification is too high.  I tightened the nut so there wasn't any play up and down but the rotational force was even (not tight).
I tightened the idler arm to the point of removing any vertical or horizontal play.  Probably a little less than 10 ft lbs.  Operates smoothly and probably as intended.  58 ft lbs has to be a major misprint.  Thanks, Jim and Randy, for the input re: reasonable tightness/torque.
Larry
I'm going out to the garage to check my recently installed bushing. The subframe is still out of the car, but I seem to remember I couldn't move it hardly at all. Now you guys have me thinking...I guarantee you I torque it to the quoted spec...damn.
Edited by NYNick
1974 2002 Tii-SOLD
1978 911SC Coupe
1988 Landcruiser
2020 M2 CS
Nick,
Please keep us posted.  I know the engineering and leverage of the steering box and associated steering parts are well designed and strong; however, 58 lbs really, really tightens that arm and, in my mind, will superbly tax the aforementioned components.  Maybe I am wrong.
Larry
  • 3 years later...
The idler arm bushings I got from Wallothnesch came with instructions to torque to 10nM (7.5 ft/lbs).  58 ft/lbs, sounds correct for the connection of the idler arm and steering box arm to the center link.
Mark92131
1970 BMW 1600 (Nevada)
