Pedals! What's your favorite aftermarket setup?
2002Scoob
And if you wear size 11 or larger you can move the pads on the clutch and brake over a inch or so and reweld the pads.
17 minutes ago, AceAndrew said:
Drill some speed holes, file down the front edge, send out to chrome
Show off! :D Those look amazing Andrew! Maybe slippery though?
1969 2002 Granada, 2nd owner
1976 2002 Fjordblau (owned 10 years)
A few steering wheels
Haha, how can we convince you to post more pictures of your collection of goodies?!
Yes, slippery, but I'm trying to figure out how to add some tasteful grip tape .
Another consideration would be the set from Pedal Haus.
WWW.PEDALHAUS.COM
BMW Pedals makes the best pedals for your BMW... and made to fit YOUR model!
Edited by AceAndrew
@JohnP_02 I looked at those too, almost bought them. I looked at the @AceAndrewPedalHaus set too. I ended up with the AKG E30 covers. Mostly it came down to an aesthetic decision, but they are slightly smaller than the stock pad, so you get a little extra room too.  Just needed to trim the originals before powder, then drill and mount these guys. I have and love the Ireland gas pedal too, just not mounted in this pic.
Edited by Lucky 7
I switched to the Ireland Engineering Billet Roller pedal, incredible difference, I told my friend David to try it as well and he was shocked at how good it felt.
I also added some support for the Navigators side
@chargin I have been eyeballing that IE roller pedal as well, I think I may get one! Where is your dead pedal from? Looks like Ireland is not selling theirs any longer sadly.
Roller Pedal Hack:
The most challenging part of the install was trying to get the BOLT in the bottom, it was super easy when I made a "Stud" instead and all three bolts went in from the top, trust me.
Yes it is an IE Dead pedal, you may want to email them
That’s a great idea. I managed it with the bolts, but only because I have long arms. 😂
But yeah, that pedal is such a great mod, huge improvement over stock. That nubs design leaves something to be desired.
uhhh....  no speed holes in the brake pedal, Andrew!
But yes, just a bit of grip tape- and you can pop- rivet
the corners if you use the really thick, fabric- backed stuff.
Andrew, you might try to find some rubber mushroom dots that fit through a couple of the holes to give you traction.
