5 speed won't fit!
JordanBbradley
Ok,
  So i'm on the tail end of swapping a 245 in to my 73' and i can't get it to fit! I'm getting stuck while raising the tranny up to pressure plate, I get the trans flush with the tunnel, but the input shaft needs an additional inch or so to mate up. Im thinking I need to physically move the engine(tilt it down?), but i'm not sure how. Dear lord someone help me. BTW i live in Houston if any locals want to come poke fun at me/video it for youtube/watch me get crushed by a falling transmission.
JB
Without the weight of the transmission, the engine can rock forward on it's nose (gotta be careful the fan doesn't poke the radiator)
Get a jack under the pulley/harmonic balancer and give it some nose-high attitude which would likely get you enough clearance at the bellhousing.
Ed
'69 Granada... long, long ago
'71 Manila..such a great car
'67 Granada 2000CS...way cool
Get a couple long bolts the size of the big ones that bolt the trans to the engine, cut the heads off, file some flats on the shank so they can be wrenched out later and thread them into the engine holes.  Use these as guides to start the alignment.  You will quickly see how much the engine needs to be tilted up/down/right/left and the pilot will slop right in.
I did dent, I dented with a large hammer, but only on the side where the slave cyl is. I tilted from the oil pan, until there is about 3-4 inches from the distributor from hitting the firewall. The engine is cocked to drivers side a lot. Wiggling ensued, I still can't get the input shaft closer than about an inch away from the receiving hole. Should I loosen the motor mounts? if so where, and I don't have an engine jack.
Feels bad guys :(
Jimk, I guess my big problem is how do i tilt the motor and move it around?
Edited by JordanBbradley
JB
tilt the engine back until the dizzy is almost touching firewall.  loosen the  engine mount bolts a bit to allow flex.
you can also unscrew the bolts holding the subframe to the frame rails about a half inch each.  this lowers the engine just enough to get some room.
Edited by mlytle
2xM3
Good point!  I've done that also and have some lonter bolts for there too.
"you can also unscrew the bolts holding the subframe to the frame rails about a half inch each.  this lowers the engine just enough to get some room. " -
Great idea that I never thought of while I was there........
post-46690-0-06726000-1456503333_thumb.j
I don't take myself or opinions Seriously
My 4th 2002 and the first set of Square Tail-Lights
See the 4 versions of my 2002 project here: SoCal S2002 | Facebook
