m10 with s14 crank
jamesnutter50
Right I am starting to get the bits needed to put an s14 crankshaft in to my 2002.
I have done alot of research on here and I think Im right on saying the best way to go is -
2.3 s14 crankshaft
standard s14 rods with custom pistons (do any were stock ready made ones?)
modify the front timing case to take the s14 front seal and pulley.
Are there any other things I will need to do etc ? or places to buy parts to make the build easier ?
Thanks for any help
James
For high performance applications you may want to consider rods longer than 144mm, with raised pins in the pistons for a better rod ratio. Any more details of your build?
--Fred
'74tii (Colorado) track car
'73tii (Fjord....RIP)
I think the stock S14 rods need to have the block clearenced. I have Crower rods in mine and they are svelt enough to not need any mods to the block. Also Eric Kerman turned the end of the crank to take the 2002 timing chain gear and 2002 pulley and thus the un modified timing cover and 2002 oil pump chain.
John
1665778
John
could you clarify this?
i was under the impression that using the S14 crankshaft pulley only required modifying the lower timing cover crankshaft seal diameter. i was unaware of additional mods to the chain gear and chain.
btw, several years ago inkatouring posted photos on the FAQ showing where he ground clearances in the engine block for the S14 rods. it was primarily at the base of the cylinder bores; didn't appear to be much.
& 1 special alfa
John
The crank from an e30 2.3L s14 has a male front end, the pulley is fastened using a 36mm nut (M24-1.5), and torque spec is 440 N-M (324.5 ft-lbs.)
In my stroker motor, Kerman took a male 2.3L crank and made it into a female 2.3L crank by turning down the front end and tapping it to accept a bolt. Specifically, an SAE 5/8"-18 bolt. The torque specs for a grade 5, 5/8"-18 bolt indicate that it should be tightened to approximately 170 ft-lbs.
It also appears that the water pump was modified to properly align with the crank pulley. Specifically, the water pump shaft was shortened, and the front of the water pump milled by about 3/16" to allow the water pump pulley to clear the front of the water pump.
If I recall correctly, the bottom of cylinder #4 needs to be ground slightly to allow clearance for the stock s14 rods.
[EDIT] Based on the photos of Steve's build, it's probably the bottom of cylinder #1 that needs grinding. Also, my motor uses a 2002 M10 crank pulley, not an s14 crank pulley.{option}[/img]
williamggruff
This is brilliant, that link basically answers all of my question's. I will send this on to my engine builder to have a look at.
were is a good place to buy pistons ?
Regards
James
Hi James - how's tricks? Ireland Engineering is a good bet - Jeff or Jeremy will know exactly what you're talking about and be able to spec up the right piston for your build. I would say phone them and not to rely on email coms so much, but back up anything on email so there's a written record of what you're ordering. Postage shouldn't be a killer, but allow for VAT and import duty when they land in the UK. There are obviously places in the UK that could supply, but can you trust them to know your exact requirements for a hybrid m10 (e12 or 121 head for example)?
Cheers, Nick
I have always been interested in the 2.3 stroker motor. What type of HP and torque gain can one expect? Say you have a 9.5 Comp M10, 292 cam running a 38/38....you build a M10 to a 2.3 stroker, 292 cam 38/38 carb. Any idea what the potential gain will be. I just am looking for a rough idea. I have looked at M42's, S14 etc etc to put in my car but I really enjoy the simplicity of the M10 in it. Just am wanting more power. I drive it as a DD so I am trying to stay away from duals, would go EFI but prefer the 38/38 if it can be used with the stroker
I'm not as dumb as I look
74 Verona
06 Audi A3
09 Mercedes C300
06 VW Passat
03 VW Conv Beetle
I'm curious to know why one would choose to mill down the S14 crank (which I believe is hardened) as opposed to just boring out the M10 lower timing chain cover. I had the latter done by Terry Tinney and it was something like a $50 job and would seem much less risky than messing with a hardened crank. Is it so that you can use the stock M10 pulley?
Right on!
John
1665778
I would stick with the s14 pulley (damper). BMW had a reason for using it.
The s14 crank has much bigger and heavier counter-weights then the standard M10 crank. I suspect that there are some resonance (harmonic) problems with a regular, non dampening pulley at high RPM.
The lowest price I found for the s14 pulley is $469.00 at ddmtuning.com.
The part number is 11231308577
Too many cars.
