Drain Gas Tank..how?
scoopyg
What is the method for draining the 18-year old gasoline out of the tank? I can't locate a petcock on the tank, so I'm trying to figure out how to drain the gas and flush the tank. With my Volvo 1800, there was a petcock at the bottom of the tank, and once drained I just water-flushed the tank and it worked great.
Check the bottom of the tank for a drain plug.  Some had them, others didn't.
If no plug present, try a siphon type hand pump as mentioned by Hans ^ or rig up an electric fuel pump with some hoses, spare battery and toggle switch to pump the old fuel into a spare container.  Remove the sending unit so you can fish the suction hose around the tank. Safety first though - keep the electrics away from the open fuel tank.
AFAIK the factory installed 2002 gas tanks all had drain plugs; replacement tanks generally didn't.  Regardless of how you drain the tank, though, be VERY CAREFUL.
1.  Do your draining outside
2.  Ground the car to the drain pan or container so there's no static electricity charge buildup that could cause a fire.  I've seen a car go up in flames (and nearly take an entire dealership with it) when this happened.
Were it mine, I'd remove the tank from the car and very carefully (don't forget the ground strap) empty the tank into a container.  A half-full tank isn't that heavy, and it's a safe way to do it.  Just BE CAREFUL.  Gas is scary stuff, especially in hot weather when it's volatile.
cheers
