idle jet clogged AGAIN
As some of you may remember I had a problem with a clogged idle jet earlier this week. I fixed the problem with carb cleaner and compressed air, and it worked fine. Unfortunately after driving the car 100 miles it clogged again. The fuel filter was replaced about 700 miles ago. IS there someway I can remedy this situation before I have the time/money to pull,hot tank, coat the fuel tank and replace the lines? Im thinking maybe another fuel filter (seems like if one doesnt work two wont either though). I also have a 32/36 and intake manifold that are supposed to be in good condition that I am going to eventually swap in, will this fix my problem? thanks guys,
Connor
www.VintageAutobahn.com - BMW Parts & Vehicle Import
last idea first - NO - swaping your new 32/36 carb
and manifold won't cure the crud i your fuel supply.
remove the gas tank sender unit and clean it's strainer
(first wait till you run the present tank down to RESERVE
level so you have little remaining in the tank to deal with.
If you fint the strainer is missing because P.O. removed it
for MORE POWER - buy a new sending unit.
With that tank sender/pick-up removed - mop out the
tank with a oily rag to pick up any dirt and crud.
If you can see that the inside tank metal is rusted - forget this
tank. REPLACE IT - their CHEEP and available. Forget about
future poor running or worse when on a trip with the car.
install a clear gas filter so you can monitor how much
crud your accumulating.
keep cleaning your jets - now your an expert, and it's good
maintanence anyway.
'64 R27 250cc #383851 18,000m
you don't need to pull the tank
reach into the large hole on top - where
the sender/pick-up comes out.
remove your trunk floor board on the right and look see
thats slide show is pretty much it. i blew some air in the hole for the idle jet to try and remove any excess gunk. though I dont know if that really did anything. when you pull the idle jet it has 4 holes in it. one of these holes should be clogged, spray the shit out of it with carb cleaner and reinstall.
with decent mechanical skills how long would you say it would take to pull, clean, and reinstall the gas tank.
If your filter is installed between the fuel pump and carb, the dirt is in the carb. You don't have to clean the tank, the filter is doing it's job. Filters upstream of the pump just make the possibility of pump vapor lock more likely in hot weather and create more of a system that is not filtered. The screen in the pickup assembly in the tank is sufficient so the pump is not harmed by anything small enough to get thru the screen.
But if you like messing around, cleaning the tank does no harm.
Some carburetors have a fine mesh strainer (element) at the inlet fitting. I don't recall if the Solex units have one.
And - if you are using a super cheapo plastic fuel filter (white or opaque with yellow cone-shaped internal filter), some of these can disentegrate based on all the additives used in the fuel today, sending the tiny filter fragments right into your carburetor.
And - if your fuel lines are old (or you are using vacuum tubing), the insides could be breaking down.
Careful when using those glass ones that have the screw-on ends. I used one on my 75 VW (Single 40 DRLA Dellorto) and one of the ends fell off!
Try to find a good molded plastic one or aluminum canister (like the tii ones). The last one at the bottom of the Dan's ad are typical for BMW's and VW's - just inspect them closely to see if there is any "fuzz" inside the element that could work out.
Here is a close-up of the plastic one: http://www.cbperformance.com/catalog.asp?ProductID=576
Make sure your float bowl is clean....
you can accumulate a metric buttload of junk in there,
and then it gets sucked in at random times.
If you really want a GOOD filter, you need an EFI filter.
I seem to remember that the 1984 Nissan Stanza had hose ends
instead of bolt- on fittings, but I'm sure there are others.
The little plastic things are usually adequate, though.
Usually.
