Adhesive removal from aluminum grille?
jlandreth
If you take the side reflectors off (new ones are cheap from BMW but don't say Hella?) you might be able to pop them in the oven to heat up the glue then work carefully with a scraper blade from behind to pry them loose. This is my method for removing roundels from hubcaps. Do this when you wife is not home....it smells..
Ben
--> 1968 2002 <--
Depends a lot on the adhesive you are trying to remove. If its pressure sensitive, you could try some of the commercial products available for this such as "goof off." But even WD-40 will dissolve most adhesives. (I'll bet even seafoam, which is a petroleum distillate, would work - after all it is reputed to remove carbon) A popsicle stick is also good to avoid scratching.
If you are trying to remove something stronger than pressure sensitive adhesive, good luck. JB Weld and epoxies and crazy glues will require something stronger to break what comes close to a mechanical bond. This might include heat, cold or physical force.
Good luck
press the tape on the adhesive then peel the tape back. It may be slow and teadious but sometimes it works well. If it is an acrylic adhesive the use of any solvents will be ineffective.
Don
Lacquer thinner will do it-
but it's painfully slow. I wanted to set
up some sort of bath for it, but couldn't come
up with a big enough enclosed container.
The thinner evaporates hellaciously fast, and then
the icebergs show up out in the Puget Sound....
This is kind of "scavenger-ey" but a great solvent washing container can be made from the soap containers that the car wash throws out (I mean recycles.) The 5 gal polypropylene plastic (thats the milky translucent ones) resists laquer thinner (the 5 gal pails (opaque white)won't). Get the rectangular boxy one and cut a hole in the top for access to the work. It's a great parts cleaner and then you can recycle it after using it.
