Turbo-sized cheap alloy radiator
NickVyse
I wanted to improve the cooling capacity of my stroker motor, esp with summer here and AC in the future. After a bit of research it seemed an Opel Manta radiatior might work nicely - 5cms wider and 1cm taller core, and there was a cheap triple core Chinese alloy version on Aliexpress for €150 delivered with tax. The outlets were supposed to be 34mm, so I was going to see if the 32mm 02 hoses would be long term happy at that stretch. The good news - oem hoses lined up. The bad news - the Chinese radiator came with 35mm OD fittings. I temporarily squeezed on the 02 hoses, but it wasn't a proper solution.
Bit more research and I found two hoses that cut down to OEM shape and were 34mm - happy compromise that works well. Now just waiting on some new decent hose clamps to finish it off.
You obviosuly have to cut the radiator opening wider, so it's not for everyone. And like all triple core rads OEM fan fitment is very tight - I've got an s14 crank pulley which doesn't alow for the red fan anyway.
[edit why is it only in photos that I notice how filthy my car is?]
Edited by NickVyse
  • Like 5
This is great info Nick, thanks.
Which makes me wonder...for those of us in the US where Opel Mantas are thin on the ground, is there a US car whose radiator fits the '02?  Availability at one of the millions of FLAPS around the country would be a huge plus.
Luis
good question - but if you're happy buying from China then there's no problem with Opel Mantas being thin on the ground. Whether the hoses are available stateside is another question:
Radiator: https://fr.aliexpress.com/item/1005005306855430.html
Lower hose to cut down - GATES 3317: https://www.auto-doc.fr/gates/1235729
Upper - GATES 05-0218: https://www.auto-doc.fr/gates/14357791
The Ford Pinto was the go to hi capacity radiator back in the day.
I had one of the Chinese manufacturers that sell on eBay make me a custom radiator for my S14 swap.  They advertise a stock radiator for the 2002, but the dimensions are off.  I measured my car for the OEM opening, provided a drawing of where I wanted the hose connections and they built it in 2 days and shipped it to me.  It fit perfect out of the box.  I did need to get creative with the hoses and cobbled together connections for the upper radiator hose and S14 thermostat.
If you want to go this route, hit me up and I'll send you my drawing and contact for the manufacturer.
Mark92131
1970 BMW 1600 (Nevada)
Mark92131
Is your radiator in service now.  Is it cooling ok?
25 minutes ago, Mark92131 said:
Haven't fired it yet, I am a couple weeks out, still solving problems.
Mark92131
Dang that looks sweet. I am always keeping an eye peeled for one.  Just in case.
"Goosed" 1975 BMW 2002
Mark92131
Is the head vent routed below the pressure seal of the radiator cap?
Nick I believe you are going to run into an issue in the future with the rotary compressor fouling the lower hose, because that port is not angled.
GL,
Ray
Yes, is that going to be a problem?  It normally runs to the back of the head and just dumps into the reservoir?
Mark92131
Mark92131
Did I phrase the question correctly?  I meant on the tank side of the cap seal.
Should be ok so long as there is a flow path for constant circulation to the radiator top tank to get the air out of the head.
Edited by jimk
GL,
yeah, having removed an AC rad I knew this would be an issue, but there's a local guy who can weld alloy beautifully, so I'll get it modified when I get round to the instal (and use a 32mm fitting so I can stick with the OEM hose).
