My 2002 Journey so far (Reso '76), WTF/Dtech/NorthBay/Koogle
mic_crispy
Its difficult to summarize 2 years of this process into a few paragraphs that someone could actually find useful or enjoyable to read.. but here it goes:
This purpose of this thread is really just give share my experience, things ive learned and just have someone listen as my wife is tired of hearing about it, ha.
2 years ago I had the fantastic idea to buy a 2002 and start a resto-mod project.
I ended up purchasing a '76 which already had a M42/5Spd put in which at the time seemed like a huge headstart..
In reality, i would have been better served buying a shell, or perhaps as near stock as possible given what i wanted the result to be (a 7/10 drivers resto mod).
I never intended this to be a consours example, just something very clean that i could drive a lot and possibly make some money further down the line when/if i decided to sell.
The car initially went to my good friend Curtis at WTF Motorsports in Orlando FL with the intention of him building this out, but his workload became too much to dedicate the time to my build. He's a great guy, but has high demand on projects that honestly will make him more money in a shorter amount of time, so i totally understood.
From there, as I was in the process of moving to DFW, I found a local shop that seemed to do some interesting builds: Dtech/Select Classics.
Now, I didn't know this at the time, but apparently this shop has a very negative view on this forum which i think is only partially justified.
These guys did most of the body work (trim, some welding of holes, fenders, paint). They also installed most of the interior (Seats, Carpet, AC/Radio).
There are things that they did well IMO, the bodywork is fine, and even the paint isn't terrible for a budget job... They seem to work with any budget really, for better or worse.
They didn't pull the motor, so you could still see the original green creeping up in all sorts of places, but that is mostly to me not wanting to pay the money to do a full engine out respray.
I had the seats reupholstered there as well (Front/Rear) and i think they just did a bad job for the cost (2k), especially with the fronts. Money wasted.
We also ended up replacing tons of exterior/interior trim (including the headliner) and they did a good job here.
We put in their AC kit in which proved to be pretty difficult with essentially no documentation out there on how to get modern AC in a M42 swapped 2002...
The wiring on my car was an absolute disaster area and they seemed pretty lost in getting it fixed. I understand nothing is standard or documented here, but they really should have just given up or rewired the whole thing, as when it left their shop the amount of wires just floating around or barely attached was alarming. I spent alot of money that just ended up in some rework later.
So while i have a bit of sympathy of the mess that was delivered to Dtech, i feel the finer touches just weren't there given the money spent.
I think if you're working with a more/less stock or OG 2002, they will be just fine and can even do some neat things.
From there, my travels took me out west, and I needed to finish this thing finished up, so i sent it over to NorthBay Bavarian(Rick) for a mechincal look over and KoogleWerks to finish the interior.
I wanted NorthBay to take a strong look at the car from a mechanical / drivability perspective because you can just never be too sure. We found enough that needed fixing with the original swap (before i even got the car) to necessitate pulling the motor and really replacing every bit we could. Mounts, hoses, seals... and while it was out, we decided to paint the engine bay and rewire the car... so in retrospect, i should have just pulled the motor from the beginning as i really did things in reverse order. Live and learn .
Ricks work is top knotch and he now only knows what he is doing, but is the type of guy who will fix little things he see's along the way just because. Couldn't recommend them more.
Over at KoogleWerks, i wanted him to tighten up the interior abit (new seats, glue carpet, make a custom console) and he has done just a fantastic job.
Forrest is a true artisan and his deep passion for these cars shows. He's given me some great pointers and helped me tighten up some vision components here and there.
All in all i pretty sure this thing is 80% new parts, lol. Afew things i know i want to fix in the near term would be lining up the flairs/front dam better, getting a very light tint and perhaps a different steering wheel. Also, while the coilovers, sways and most bushings are new, there's still other suspension components i think id like to upgrade from stock
I have about two more weeks before i'm really out in about in this thing and im sure ill find 100 more things id like to fix then, but as of now, this is where my journey has taken me.
Attached some pictures for the curious..
As delivered:
Nearly 2 years later...
(And yes I know the hood isn't closed properly.. that is thankfully fixed now).
Build Details:
Motor/Drivetrain:
M42B18 (E30)
Getrag 240
Custom Short Throw Shifter
Kooglewerks Aluminum Hood Hinge/Prop Set
Kooglewerks Aluminum Skid Plate
New Fuel Lines, Hoses
IE 5speed Transmission Weld-on Brackets
IE 5speed Rear Cross Member
Dtech AC Kit (w/ Denso Compressor)
Suspension:
CATUNED Coilovers
IE Swaybar Kit
E12-24 Trackrod
Brakes:
Stock Rebuilt + Braided Lines
Wheels:
BBS RS032 - 15x7.5 ET4.3
Falken RT660 - 205/50/15, 225/50/15
Black Lugs
Exterior:
E46 Titan Silver
Undercarriage Painted Black (Epoxy)
IE Turbo DAM
IE Turbo Flairs
New OEM Beltline Trim
New Tailights
New Headlights
New Tail Panel Trim
All New Rubber (Windows, Doors)
Euro Rear Bumper
Euro Turn Signals
New Emblems
New Front Grill Surrounds
Knee/Ankle Removed / welded
Side Markers removed / welded
Antenna Delete
OEM Chrome Gascap
Interior:
Recaro LX, Black w/ Yellow Stitching
IE Wood Steering Wheel + Hub
IE Anodized Shift Knob (Black)
IE Door Sill Plates
Kooglewerks Shift and E-Brake Boot
Kooglewerks Center Console
Kooglewerks Speaker Pods + Under Dash Panels
Custom Rear Speaker Location (Under Seats)
Custom Gauge Faceplate
Black Suede Headliner
4 Channel AMP w/ Bluetooth (Headunit Delete)
New Front Door Cards
Rear Side Cards Reconditioned
Full Interior Carpet Kit (Salt/Pepper) - Dtech
Edited by mic_crispy
Updated
  • Like 3
'76 - 2002 - RESTO M42/5SPD
'93 - 964 911 - C2 MT, Rebuilt
991.1 C2S 7MT
M340i
Looks great! I love the M42 and think it would be great fun in an 02.
Car will turn heads wherever it goes!
Thanks for sharing the journey.
~Jason
1973 2002tii (2764167), Baikal, Rebuild blog here!
--> Blog: Repro tii cold start relay;   + --> Need an Alpina A4 tuning guide? PM me!
5 hours ago, Dudeland said:
Such a great project.  Share more about the build.  Motor etc...
Thank goodness you had your droid to help you out.
Its a M42 / Getrag 240(245?) from a early E30
Motor is basically stock, just with a custom header from Classic Daily, Exhaust and slightly different intake than OEM to fit.
Total parts list here if you're curious, plus good exercise for me to do an inventory.
1976 BMW 2002
Non-sunroof Car
Rust Free
Motor/Drivetrain:
M42B18 (E30)
Getrag 240
Suspension:
CATUNED Coilovers
IE Swaybar Kit
E12-24 Trackrod
Brakes:
Wheels:
Black Lugs
Exterior:
E46 Titan Silver
IE Turbo DAM
IE Turbo Flairs
New Tailights
New Headlights
New Tail Panel Trim
Euro Rear Bumper
Euro Turn Signals
New Emblems
Antenna Delete
OEM Chrome Gascap
Interior:
IE Door Sill Plates
991.1 C2S 7MT
M340i
4 hours ago, AceAndrew said:
I like your trim choices.  The gauge cluster, early door panels, rear bumper, KW hood hinges, and wheels are a nice pop on the subtle grey paint color.
What driving trips are you planning?
Thank you! As of now, just puttering around town...
991.1 C2S 7MT
M340i
There are chips (still) available for that M42 that will add 10-15 hp, and move the torque band onset down about 1k rpm.  I have one in my 318is, and compared to a stock M42, there's a real noticeable difference.  Might be worth looking into, especially since you probably still have a 3.64 diff, while the diff in a 318is was 4.11.
That's good to know! Did you have any specific in mind?
991.1 C2S 7MT
M340i
There are several - MarcD's, SSSQuid, Turner and likely more! I really want one but just haven't yet.
I've heard positives about all of them and most likely will go with SSSquid's based on some dialog on rev3limited M42 channel. I honestly don't think you can go wrong though. Feels like they run $200-300.
This is great to know! Ill be adding this for sure.
991.1 C2S 7MT
M340i
