Filter King & DCOE - Fuel line routing
Leucadian
Go to solution Solved by AceAndrew,
I just picked up a filter king and gauge from I.E and I plan on mounting it on the firewall, similar to this setup:
My question is regarding the routing of the fuel lines back to the carb from this location, and where/how I should mount the pressure gauge?  Does anyone have close ups of a similar install?
Can I run a 90 degree fitting off of the carb and a 90 at the filter and connect the two?  Or should I just snake a line from the carbs to the filter and call it a day?  Crude drawing with my setup, for reference
Thanks!
Engine bay OCD is a real problem
@02carbs
1 hour ago, AceAndrew said:
The inlet on my filter king is on the left (which is where I drill/tapped for the pressure gauge).  The right outlet I’ll just loop the fuel hose around.
Never occurred to me to drill and tap.  Thanks!
@02carbs
Didn't want to start another thread for this, but I'd like to remove the bracket on the firewall that held the emissions control equipment:
Is it possible to take an angle grinder to it and cut it out, or will that leave a sizeable hole?  There's also not a ton of room to maneuver back there.  I just want a smooth surface where I can mount my Filter King.
@02carbs
51 minutes ago, scanner said:
Emissions control bracket looks like a good place to mount the filter king without having to make holes in the firewall?
That was my original thought, but I may not have clearance for the gauge on top of the filter, like Andrew's setup.
I'll test fit it when the gauge and mounting bracket arrives
@02carbs
That's what I did. My engine bay has a lot more patina though....   I put my fuel pressure gauge on  90 deg. elbow to make sure it didn't contact anything. I actually like it this way as I can glance over and easily see it while I'm leaning in to the engine bay adusting the carbs.
If you remove that mount you'll sure screw up that nice paint, I think I would make a plate that screws to that mount and allows the filter to be mounted low enough to fit the gauge.
  • Like 3
George S Patton
