IE 5-speed shift plate feedback?
While my car still shifts great, I think there's starting to be a bit too much play in the shifter.  Been thinking about doing a rebuild, but then there's the fact that my car has a 5-speed conversion with a modified stock shift plate.  For just a little more money, would it make more sense to 'upgrade' to the IE 5-speed shift plate, or should I just continue with the stock-style rebuild?  Not planning on changing to a shorter shift lever; I'm used to and like the longer stock throw in that car.  Any feedback from users/installers? Do I need to drop the transmission to change out the plate? Don't mind disconnecting the driveshaft, but if it's necessary to move the tranny out of the way, I'll pass.
I used IE shift plate a few years ago. Initial plate would not allow engagement into all gears. Replacement part was modified, albeit a little crudely, but it worked fine.  They were very responsive and I imagine have changed design since then. I also installed their short shift kit.  In my opinion, Blunttech has the nicest shift platform on the market currently.
1960 Austin Healey Sprite | 1974 Ford Bronco | 1988 Porsche 911 | 1994 Toyota Land Cruiser | 2022 Ford Bronco Badlands on Order | In Search of a BMW 2002
I just installed mine about a year ago and it didn't fit. IE doesn't say it wont work, They just recommend the short shift kit, But they definitely should say it doesn't work with stock shifter
I dont have any experience with the IE shift plate , I modified an E21 shift plate and  stock shift rod.
Seems like you cant get the teflon bushings that wear out in the  stock shift lever stub and have to buy a new part just to get 2 new little bushings Screw that.
I bought 2 bronze bushings at Ace Hardware, 1/2 in OD, 3/8 ID and pressed them in with a vise. Had to cut some of the excess length off with a hacksaw and dressed flat with a file. Ran a ridiculously cheap on Ebay 10mm ream though them after pressing in. Got the idea off the Faq but cant find that post right now.
put a new joint at the trans.
It works and you can do it with relatively simple tools.
No exhaust , driveshaft or trans fiddling.
Some good pics/info here:
I suspect you may have some fitment issues installing an IE shift platform using your existing shift lever and rod.
Edited by tech71
76 2002 Survivor
71 2002 Franzi
85 318i  Doris
