Wiper Repairs
esty
When working on my wiper motor and linkage, I found that I could pop one of the ball joint linkage joints near to the motor pretty easily with a screwdriver.  Then the wiper linkage between the two sides kind of folds up skinnier and can come out past the fan cage.  The same joint then squeezes back together with a carpenter's clamp afterwards when things have been reinstalled .  Hope this is the question you asked.
Edited by JMMcR75
add picture
John McConaghy
1974 2002tii Verona 2780988
1972 2002tii Chamonix 2761282 (wish I'd never sold)
Freude am Fahren
i'll see if i can make that work...thanks for the tip
I think you are exactly right, Hans! I thought about this right after making the suggestion. The cruder approach was just what I did at the time. A terminal puller should be the correct tool for both removal and re-installation.
John
John McConaghy
Freude am Fahren
John
Or wiper arm puller. The bushings on my NK are N LA.
On 9/19/2020 at 5:15 PM, esty said:
hoping for help
i cannot get the wiper motor and linkage out of my 73...the linkage is in a position preventing it from clearing the heater fan...i don't want to pull the heater box but believe i should be able to power the motor with a jumper wire to move the linkage but reading a wiring diagram i cannot figure out which terminals i need to power and ground to move the linkage that is disconnected from the body...i need to rotate it about an inch
@esty    Brown is ground and either of the black wires are positive, assuming two speeds work.
Edited by RichenFamous
