Tii Clock Repair Revelations
Actually, after I repaired my clock and it stopped working again, I spoke to the folks at The Clock Works and they seemed to imply that the VDO and the Kienzle were the same.  I believe Keinzle is a very old clock maker and perhaps VDO gets the mechanism from them.
I have no affiliation with them, but had excellent service.  www.clockwks.com and give them a call
Dave A.
'72 2002Tii
'74 Alfa Spider
  • 3 years later...
Paul, many thanks for posting this... I was pulling my instrument cluster to today to install the '72 year/model correct replacement, and I thought:  "Heck, I might as well keep going and take on the clock at the same time!"
Pulled the console and got the clock out easily enough, but I shudder at the prospect of getting it back in!
I kind of like Mike Wooldridge's solution of NOT installing it on the bracket, but I'll give it the "old school try" armed with Paul's handy "knurled nut placement tool"! :)
I have a related question:
When I pulled the instrument cluster, I found that the dealer had done a funky job of wiring in the clock.  They piggy-backed the clock power off of the tacho power and cluster perimeter lamps. Most likely they didn't have a second 3-pin connector for the clock.
It will work, but I've read on other threads that the clock is actually powered off of another three pins on the right of the back panel Circled in blue):
I have verified that they share the same 12V/Ground circuit, so I'm inclined to separate the two circuits per the original configuration.
My question:  Does anybody out there have, or know a source for an extra 3-pin plug to use on the right-hand pins (and connector pins)?  I can jury-rig a connection, but I'd rather have the real deal.  I have seen a thread where somebody had a friend 3-D print one, but haven't found the thread yet.
Next step is to pry off the bezel and work on the clock!  Here goes...
1972 BMW Inka 2002Tii  ?
1974 BMW Turkis 3.0 CSi ?
1972 MBZ Weiss 280SE 4.5
2006 BMW Cobalt 530i (38,700 m original)
I am not sure why BMW wired the clock in the cluster to the round set of pins on the cluster (circled in blue) and used the triple half moon pins (circled in red) for the ti and tii clock.  FAQr Tsingtao can hook you up for clock works.  Something about the lights for each one.
Edited by jgerock
The pic is the back of one of my clusters and the tach is fed from the far right connection (ringed in blue), and thus the tii clock from the connection ringed in red.
This also the connections shown in my Touring Handbook for the tii. Hopefully you can make the pic bigger.
Edited by 02Les
Les
'74 '02 - Jade Touring (RHD)
'76 '02 - Delk's "Da Beater"
FAQ Member #17
On 3/18/2014 at 11:08 AM, PaulTWinterton said:
Anyone know why these stop working, as I've been told there is no internal fuse,
I attempted to repair 2 late Tii clocks with the circuit board.  One was dead electrically.  With no circuit diagram and no parts list, no hope of doing anything.  Also, the magnetically suspended balance wheel (pendulum) got out of whack.  It could not be adjusted back in place.
The other was good electrically.  Two of the nylon gears were not engaging correctly.  Some disassembly, readjustment....  It is still running and keeping good time.
