I'm installing relays for the headlights in my 1972.  The single high-beam white wire in the engine compartment serves both left and right headlights.  However, there are two low-beam wires, the left is yellow/black; the right is yellow (or white)/blue.  The question:  Should I splice the two low-beam wires before and after the low-beam relay?  If not, then what?
Thanks!
Fran Ferrance
Ferrance@aol.com
I did a column on this--adding a high beam relay on a 12 fuse roundie; drop me an e-mail with your e-mail address and I'll send you a copy.
It also covers the same job on six fuse cars, and IIRC, squarelights.
cheers
cheers
Mike, I too would like a copy: iammrbill@sbcglobal.net
Thank you!
75 2002 (atlantik) 1990 - 1993
73 2002 tii (malaga) 1994 - 2017
74 2002 tii (verona) 2023 - present
  • 7 months later...
cheers
I'd like to get a copy of this as well if you still have it.
Cparent79 at gmail dot c o m
Thanks
