Cylinder Hone Size What Do I Need
jcnnjc
Go to solution Solved by jcnnjc,
what size ball hone or dingleberry hone size do I need looks like they have them in 89mm and 95mm
the motor has not been bored out so so it should be close to 88.97 stock dont know if the 89 will do it or if the 95 is 2 big?
Thanks
Jim
1970 2002 gone
1972 2002 gone
1973 2002 gone
1974 2002 just started resto
2002 Mini Cooper
1997 Bmw z3
I think I used a 3.5" ball hone on my tii engine (89.47mm pistons)
Not shown is my extensive taping and drop cloth done for each cylinder (oil pan was off).  I put a rag down into the bore just above the crankshaft with the journal about 90 degrees from TDC to catch the grit.  I also got one of the bore brushes from the same company as the hone.  When doing this I was surprised at the amount of grit that you need to remove from each bore after honing.
Bore size
New rings
I would like to point out that digital calipers are good for plus or minus .001" and most likely a lot worse.
For accurate measurements use a micrometer.
Too many cars.
You are correct.  I would not do what I did again.  The use of a snap type bore gauge and digital calipers is not very accurate. So far the engine work I performed in 2009/2010 has worked out fine.
