I think i have a battery drain. any common places to start?
flyingfool
I had to get a new battery and when i put the new one in, car fired right up, no issues. took it around the block a few times just for kicks, and then parked it. went to go start it up 2 days later, and now dash lights and such barely come on and i get no action.
(lights and such are off.)
there's not much potential for parasitic drain on a 2002. Perhaps a radio on un-switched circuit? As suggested, I'd look at charging system first. With engine running, you should see 14v at battery. Loose belt would likely create cooing issues. Some have reported drain thru alternator fault. For instructions for testing for drain, search on Bimmerforums E46 page - I saw it there recently.
if it's in the budget, get a current clamp meter that does DC* (or find a friend that has one). Charge the battery, (play with the meter on the charger to learn how it works, remove when charged) Clamp around one of the battery leads (doesn't really matter which). If there is current flowing, start yarding out fuses to eliminate circuits, zeroing in on the culprit.
*Not all clamp meters do DC, confirm in the specs. Alternately, there are addon clamp meters if you already have a good meter.
After you charge the battery, take any multimeter and put it in a range that will let you measure .5 amps DC.
With everything turned off, pull one fuse at a time and connect the amp meter to the fuse terminals. The positive lead goes to the hot terminal.
If you read anything, you found a leaky circuit. Be careful, if the meter is connected to 12 V and the other lead is even momentarily grounded (while your'e in the current measuring mode), you will most likely destroy the meter.
It is also possible that the battery is draining through some bad diodes in the alternator. As was mentioned before, a clamp-on DC amp meter is the most convenient way of checking that, but a regular meter will work too.
Too many cars.
i'd start with removing the negative cable from battery and connecting multimeter in Amps mode between the negative post and the end of the negative cable. If there's current, you've got parasitic draw. Then go to the fuses to determine which circuit/s are to blame.
f.fool ,
alternator history ?________________
how old is alt. ?___________________
describe condition of wires to alternator and batt. ? ________
is there a clean solid GROUND cable from Batt to BODY ?____
is there a GROUND from Engine Block to Body ?_____
is there a GROUND from Alternator to Eng Timing Cover ?_____
was alternator replaced since you owned the car ?____
source for the replacement ?_________________
have you had charging issues ?_______________
do you know Volts @ Batt. key off ? ________V
do you know Volts @ Batt. @ idle speed ? ____V
do you know Volts @ Batt. @ 3,500 RPM ? ____V
do you see any instrument lights glowing
with motor running ? _____
how long have you owned car ? years?__ miles?__
is there a radio/big audio installed ?__________
is there a bundle of wild wiring anywhere on the car ? _____
do wipers, all lights, heater fan work correctly ?______
'64 R27 250cc #383851 18,000m
f.fool ,
alternator history ?________________newer looking since i got it. clean compared to rest of engine
how old is alt. ?___________________unknown
describe condition of wires to alternator and batt. ? ________bit greasy but have cleaned then with bit of steel wool
is there a clean solid GROUND cable from Batt to BODY ?____will check on that
is there a GROUND from Engine Block to Body ?_____ground from baided cable from block to battery. could be replaced
is there a GROUND from Alternator to Eng Timing Cover ?_____have to check
was alternator replaced since you owned the car ?____no
have you had charging issues ?________ never had any issues.
do you know Volts @ Batt. key off ? ________V 6
do you know Volts @ Batt. @ idle speed ? ____V will check tommorow
with motor running ? _____ no
how long have you owned car ? years? 3 miles?__
is there a radio/big audio installed ?__________yes. does not work
is there a bundle of wild wiring anywhere on the car ? _____nothing that looks to out of the ordinary
yes, except dash lights. they have been intermitant. fuse usually
Before you do anything else, check if you have any drain on the battery when everything is turned off. If you do have some current (more than 20MA) pull one fuse at a time and watch the meter.
If pulling the fuses makes no difference, disconnect the alternator. Do that and report back please. Measuring is better than guessing.
Too many cars.
Hello there. I'm following this thread very closely. My 74, which I just bought, seems to be having battery problems. Just like the opening remarks I put a brand new battery and 2 hrs later the car will 'barely' start. In my case battery is at 13V, checked alternator fine, and most important....no higher voltage when metering from negative battery end to terminal. It sucks because now I have to eliminate 'parasitic draw' which is relatively easy to locate.
Good luck with your search.
Dan in Sacramento,CA
  • 5 months later...
I am having a similar problem.  I replaced the alternator a few weeks ago and replaced the battery today.  What does the "L" warning light indicate?  I was told it meant a low battery.  That light still comes on with the new fully charged battery.
Tom
