Battery drain issue...oh joy..
ziff73
Okay, I have the small under seat set up and if I don't keep the battery hooked up to a tender, she drains pretty quickly. Before I start tearing everything apart:
A. I noticed that when I touch the ground back to the battery, I hear a click and the fuel gauge pops to life...is that normal? Is that draining the battery?
B. what should I look for, in particular, that would be causing the problem.
some background:
I have a carter fuel pump (I know, I wanted mechanical, but had to use a previously injected head) No wipers hooked up, no horn yet, and no radio. There aren't too many things on this car to begin with, so hopefully I can find it quickly.
Electrical work is my Kryptonite...I'll do it to save a kid from a burning building, but not for fun...:-)
Thanks!
Stephen
You can use fuse pulling method to home in on circuit, but seems to me fuel gauge should be off when key is turned off and removed. On 02, there should be virtually no draw - maybe with modern radio. Not like new cars. So maybe ignition switch or some misconnected wires at fuse box??
Fuel pump is good on switched power, but I just looked into the fuel gauge issue and found that it does seem to be 'turning on' when the battery is connected and when I pull the wire from the sending unit on the gas tank, it clicks back down....obviously... so my question is, why would that be constantly hot? Did I somehow attach constant power to it instead of switched, like the rest of the dash?
Man, give me an engine to rebuild any day of the week...electrical gremlins...grrr. Thanks for the help everyone.
With everything off, pull one fuse at a time and put a test-light across the terminals. If the light comes on, you found the offending circuit.
If you don't find it that way, then something is incorrectly wired into an un-fused circuit.
Too many cars.
Possibly un-fused, but definitely hot always (i.e., not on with ignition). You mentioned working on the ignition switch: I'd check your connections there. There is one "always hot" terminal that you may have used by accident. How many fuses do you have? On 12 fuse box, wire from switch to fuse that appears to feed gauge comes off switch.
