1974 02: Gas Smell in the trunk. Connect these two?
You'll also need the small spring clip that holds it in the bracket.
I suspect that I have an issue with my vapor tank as well.  While I am fairly mechanically inclined, I could not figure out the "right way" to get the spring clip out so that I can better inspect the tank and connections.
Can one of you share the trick?
TIA
74 2002tii (Sputter) - Not entirely stock - Over 18K miles since full restoration in 2014
15 BMW X5 diesel (the bombed out roads of Houston finally won)
The bow of the clip should face the tank, holding it into the bracket.  The ends of the clip are bent.  Just free one of the ends from the cut-outs in the bracket - might need some needle-nosed pliers.
John in VA
I guess I just forgot the First Rule of Brute Force - "If it's not working, you're not using enough of it"
Thanks
For anyone interested in replacing the charcoal canister: the part number is Purolator 00 701. I found the best price on the part from this source, and ordered one.
What I received was a new/old stock canister from the 1970s, and the seller was unaware of the actual application until I informed him; other 70s vehicles (including Porsches) likely used these as well. As most of you know, hookup of the canister is straightforward: the inlet accepts the line from the vapor tank in the trunk, and the outlet goes to the air cleaner or intake manifold.
If you are experiencing a faint but persistent fuel smell in the engine bay, the source may well be a charcoal canister whose odor-absorbing properties were long ago exhausted.
=1&q[search_term]=purolator%20type%2000%20701%2000%20701%20canister%20filter%201978sc%2078sc%20brand%20new]http://www.bonanza.com
Great find! They're still available from BMW, part number 16121108926:
http://realoem.com/bmw/enUS/showparts?id=2215-USA-04-1976-114-BMW-2002&diagId=16_0386
But their current price is $130-ish, versus $80 from your source. I'm particularly smarting, however, as I replaced my '76s unit three years ago when the BMW price was $250-ish! It seemed like the only game in town at that time!
Thanks and regards,
Edited by Conserv
The canister has been removed from my car.  The vent line is just open in the engine bay.  I don't really notice a gas smell.  I do use the fuel return line, so the vent is actually breathing.  I wonder why the canister is needed, if the air coming out of it was fed into the air filter/carb.  Who cares if it smells, if it is being burned again?  In fact, having more fuel in the fumes would be a good thing... no?
It was done to reduce atmospheric emissions, which don't always have noticeable smells. But for some reason, the tii's -- at least '72 and '73 -- didn't need them: the hose from the trunk-mounted tank went straight into the airbox. Do I know why? Haven't a clue!
  • 8 months later...
Digging up old threads... does anyone know offhand the size of that vent tubing??
TIA
Matt
I needed a car, and a hobby....
Nor'East '02ers-
www.bmw2002.us
Betty VIN 4229155
The original colour was Malaga, paint code 021
  • 10 months later...
TIA
Matt
Realoem quick lookup under fuel supply  - this was a generic 1972 2002.
Looks like the vent hose is 11mm O.D. x 6mm I.D. (not the tubing)
https://www.realoem.com/bmw/enUS/showparts?id=ST12-USA-03-1972-114-BMW-2002&diagId=16_0386
Edited by jgerock
  • 1 year later...
