Where to stick my new gauge?
well you need the correct oil pressure and oil temp sensors to drive it
and a mighty big hole............
oil temp sensor $16
oil pressure sensor $40
'64 R27 250cc #383851 18,000m
I like it! Unfortunately the only real place would have to be down in the center console?
Depends on what you are going for - if it's for a dedicated track car that would make it more flexible as to location.
I'm not being much help :-)
~Jason
1973 2002tii (2764167), Baikal, Rebuild blog here!
--> Blog: Repro tii cold start relay;   + --> Need an Alpina A4 tuning guide? PM me!
Maybe some sort of custom made pod you can fit on the left side where the instrument cluster bezel ends? No idea if it will even fit haha.
Nice gauge though.
2002 "tii" coupe 1970
E21 320/6 2.7 Stroker 1981
E23 730 1978
Not sure it's exactly legal to get rid of the speedo, but I like your thinking. As soon as someone manages to port TunerStudio to Android, I'm planning put a permenant tablet in the center console area for running Megasquirt, GPS, muisc, etc. To answer the other question, the gauge has about a 4-in. diameter. It *might* fit in a tii clock spot, which I'm also considering 'creating' in my dash. I like the idea of using that little spot to the left of the gauge cluster, but that will take more trickery to install cleanly there with all of those contours. Not worried about the senders, they're cheap and since I no longer have a dizzy (running EDIS) I have plenty of real estate to mount the sending units.
-Carl
