What wight and kind of oil and filter is recommended
webthread
I know this question has been asked a 1,000 times on here but everybody's set up is different. I have a 74 automatic with a crate motor that was ordered from vasek polak dealership in 1991, and installed about 100k miles ago. any suggestions on what to put in it? what is the preferred brand of filter for these engines?
1971 BMW 2002 Chamonix
Your BMW manual recommends 20w50 for most driving conditions and yes zinc is good. For filters, you can use oem, Mahle or Mann. A quality filter is key for these cars.
My 2002 was manufactured on September 15th, 1971 and delivered on October 22nd, 1971 to the BMW importer Hoffman Motors Corp. in New York City. The original colour was Granada, paint code 023. It was sold on New Years Eve December 31st 1971.
I use valvoline VR-1 20w50, my friend swears by Brad Penn 20w50. Anything with high zinc and a 20w50 viscosity will do. Don't bother with Mobil 1, Castrol GTX or any of the other synthetics that are meant for new cars, they don't have the level of protection that an old engine needs.
1971 BMW 2002
38/38 DGAS
292 cam
TEP 4-1 header
Ansa Sport muffler
Bilstein Sports
H/R Sports
Full Urethane
IE adjustable sways
15x7 König Rewind
20w50 and I've used a wide range of filters (Mahle, Wix, Fram.) I usually use a WIX.
-Nathan
Castrol GTX is not a synthetic....it is normal dino oil and its highly recommended.
Wix, Fram
I don't know what WIX is, but fram filters are garbage and you shouldn't use them. Mahle or Mann filters often cost less(blunttech has them for $4.50) and are definitely the way to go. I'll bet bosch ones are good too, but this is one place to go OEM.
Right after I bought my car the fram filter blew it's base seal out and droped almost 3 quarts of oil on the ground.
Wix is actually decent (same as NAPA Gold). I'd still go with Mahle/Mann if possible, but if you're in a pinch and need to go to the local parts store, Wix or Napa Gold are actually good quality filters.
I also wanted to say this about Zinc/ZDDP.... While I think the concerns about it may be a bit overblown, I do want it in my old engines. Yes, Valvoline VR1 20W-50 still has plenty of it, and I love the stuff in my 02. But, it's been getting tough to find lately, and it is a bit more expensive than regular dino oil. If you can get it for cheap, awesome, but if you can't... then I've found out that the little blue bottles of STP oil treatment are chock full of Zinc/ZDDP. STP won't say how much exactly, but they say its similar to what you used to be able to get in 4 quarts of old school oil before they cut out the ZDDP to meet the new standards.
So... if you want normal old school levels of Zinc/ZDDP, you could probably just add a bottle of the STP blue treatment along with your regular oil change. That's what I did in my '65 Datsun. Partly because I couldn't find 15W-40 with ZDDP, and partly because I didn't want to put expensive racing oil in a work truck for no reason.
Bring a Welder
heh... if you look at a current Bosch filter, it says Made in USA on it.
And when you cut it apart, it seems to be identical to the Wix.
20-50. Even in an E30. Unless it's winter, then 10-40's ok
ZDDP- it's essential for break- in. Especially with a high lift
cam and stouter springs.
The reason they're getting away with cutting levels is that it's not
super- critical on a stock motor with a bedded set of cam and rockers.
In fact, I don't bother on the street motors. And they don't show particularly
high levels of cam wear.
I WOULD use it for the first 5000 miles in a new motor.
And yeah, the additive packages from the cam manufacturers can be used
to boost ZDDP levels. I do that with the race car when the cam's less than
5 weekends old. In fact, that's a better way than trying to buy a ZDDP- rich
oil over the counter-- unless you buy a race oil, there's no real guarantee
that the street formulation has much in it. Delo does not, Rotella doesn't...
But when it's bedded, I run Mobil1 15-50, and haven't had a cam wear
problem with it. I run a relatively mild spring (110 seat, 250 nose) and
a moderate cam (on the order of a Schrick 315) and the lobes stay on.
According to Mobil, it still has a bit of ZDDP in it...
The cam guys desperately want you to run a synthetic- it's apparently
a LOT better with sliding friction, and makes up for the lack of ZDDP
(also good for sliding friction) to some degree.
The ring guys won't let you break in a block on synthetic.
I've started cycling the race parts so I never have to run a new cam on non- synthetic...
that's me.
The folks at Web Camshafts do NOT suggest a full synthetic, (especially Mobil1). And the Camfathers at Iksy tend to agree. But "that's them", as Toby might say - such differing opinions are typical, and part of the 'fun.'
I'm giving the Brad Penn blend a whirl, results TBD...
-KB
Penzoil 10 -40 with some Lucas.Slippery is a good thing.Wix makes all of the filters for napa and a bunch of others Fram and Quite a few others are all made by a parent company called Kadon in LaGrange Georgia.
Purolator develeoped the oiling system in this engine with BMW and provided the oil and air filter hard ware designed , it is cast into the parts.
I'm running a purolator filter from Advance Auto.It was under 5 bucks .Has the pop off valve as designed .But have 2 Mann filters on the shelf and One is going on next time around.
Catman
I did the things yesterday no one wanted to -
So I could do the things today no one else can afford.
interesting. Delta said, all things considered, that a synthetic would
take longer to bed properly, but would also have a much better chance
of not allowing 'sticking'- and that would reduce the chance of wiping a lobe.
Your mileage DOES, in fact, vary!
heh
