Kpeters
Check out my latest discovery rusty starter, rusty hoses, rusty everything besides the common rusted bodyparts. At least this stuff is easy to change!
Check out the fancy plastic tube by the starter.
This is a clear example of what water does to an engine.
....And the restoration voyage continues.
2002 "tii" coupe 1970
E21 320/6 2.7 Stroker 1981
E23 730 1978
Uhh, isn't that what a starter is supposed to look like?
Ur going to need a new radiator, fan and motor mounts.
1974 polaris A 4281992 (total resto with 5-spd conversion)
1976 jadegrun 2744974 (sold then killed by the new owner, grrrr!)
1976 sahara A 2392532 (sold)
1971 nevada 2571108(RIP)
That starter is a little bit rusty as you can see the block on that side too and leaves and stuff the car was abandoned for a while (10 years!). And its is also completely jammed last time I tried to start it well...it started smoking and almost lights up.
The fan I already got one here need to install it as surprising as it might seem the car had no overheating problems!
Thanks for the feedback on the mounts I haven't gotten into that yet!
E23 730 1978
No, our cars have always been in the Southern Arizona desert. My wife's '76 sat outside down here, undriven, for 15 yrs. before we got it and had sun damage, leaves, animal droppings, grass up inside the engine compartment - but no rust.
Bob Napier
So, if I move to AZ (which I will be doing in 3 yrs) will the rust that is on my car reverse itself. Cause I gotta tell u, if I can avoid that tab for body work, I might move that date up ;)
What's there won't go away by itself, but you won't develope any new stuff.
Humidity down here 9-10 months of the year is down in the single digits nearly every day. Plays hell with the inside of your nose, though. Drink lots of water when you get down here. Where specifically are you thinking of moving to?
Let me know if you have any other questions.
Bob Napier
That PVC tubing for your heater bypass?
John
Yeap but that wasn't me! Previous owner did it.
It was also the replacement for the tii metal tube since the car had a tii engine but I suppose that tube rustead out and the guy was cheap and just built that.
E23 730 1978
Oh my god! Hahahahahahha! That is one extreme case. How the hell did bird seed ended up there!?
And I will for sure take pics of the pump I bet it will be close to that!
E23 730 1978
