how long does it take for springs to settle?
BLUNT
Tom. Please check your e-mail. Need to speak to you. Thanks.
Armond
Sorry to Hijack.
73 Tii A4 BOD Oct. 13,1972
74 Tii BOD Nov. 16,1973
FAQ Member 1683
Mario Andretti
  • Replies 31
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Howdy,
Did you cut your rear lips?
My Toyo 195's were rubbing there with the Rota's, under acceleration the car squats -- the 195/14's Yokos did not rub.
... i think yours will settle a bit.
Cheers,
Ray
Ray
MY H&R's and Billy Sports never did in 6 years - 18,000 miles
I cut 1 coil off the fronts.
(lighter/shortened front bumper, no sunroof, battery in the rear)
NEW springs will not 'settle' - and they shouldn't !
.....and you can't judge ride height on a car just droped to the ground.
Now that everything is back together - load up the 2 front seats with 150 lbs. in each, 150 lbs centered in the back seat, full tank of gas, 100lbs in the trunk. NOW loosen the front control arms, rear control arms, bounce and roll the car at least one full tire revolution. NOW tighten up all the suspension control arms. Then drive it for 500 miles and report back.
'64 R27 250cc #383851 18,000m
On the day I put the motor in the distance from the floor to the bottom of the fender lip was 25.75
That same measurement is now 24.75.
Settled an inch.
The car is on stock suspension except for Bilstein HDs and stock tires and rims
What is your measurement at the front wheel?
1972 2000tii Touring #3422489
FAQ member #5
Howdy,
Cheers,
Ray
i rolled em till they wouldnt roll no more. i did it all before paint and looking at it i think i can go 205's all the way around even if it drops another inch.
www.BluntTech.com
FAQ Supporting Vendor
 Sales@BluntTech.com
Roll the car to the front of the garage and back a few times and the wheels will assume the right camber and you'll drop about a inch.
Marty
Don't worry about the world ending today,
Hell it's already tomorrow in Australia.
Steve:
One reason I went with H&R's and Sports is because when I put the engine back into Hugo's engine bay and drove it I was "agast" at how high it looked. I really don't think it would have come down that much "without help"...of course Hugo was a front end wreck as well, so I was worried something was wrong. As things appeared to end up, Hugo is probably better "in spec" body and frame rail wise than alot of never wrecked '02's.
When I lowered him, I was surprised that it took a little time for the suspension to settle in...but it only took one trip...and Hugo was hunkered down real sweet!
See pic...the very day I finished the H&R Springs & Bilstein Sports install!
Regardless of wheel & tire size, as long as the OD is similar to stock, "the Orange Car" should look pretty close to Hugo in no time!!!
Damn, you've done a wonderful job..gorgeous '02 man!
Best Regards,
John
thanks john, thats what i was hoping to hear. hugo was an inspiration from the first time i saw that pic of you standing next to it with no motor or trim or glass.
www.BluntTech.com
 Sales@BluntTech.com
Howdy,
Cheers,
Ray
Ok. we left about 2 or 3mm of the lip intact. You could well be ok with your set up. Hope we find out soon!
Cheers,
Ray
Ray
Settled an inch.
im actually at 23 3/4 right now. in looking at the car i still have positive camber in the front. i havent even rolled the car because the tranny is locked. all the suspension is loose front and rear.i was waiting to tighten things till it was on the ground. i think once i roll it around that camber will come out and its going to drop more
www.BluntTech.com
 Sales@BluntTech.com
i didnt see this till just now but i think youre right marty. thanks
www.BluntTech.com
 Sales@BluntTech.com
