Tighten up side view (flag) mirrors?
HLBlanton
Go to solution Solved by Son of Marty,
  • Solution
If you remove the whole mirror from the door mount you'll see a Philips head screw and spring tighten the screw a little (it's easy to over tighten so the mirror locks up) until you get it stiff enough hold but will still allow for adjustment and remount it.
George S Patton
If you haven't pulled a mirror before there's a little rubber flap on the rear of the mount right at the door I use a dental pick to pull that open and then there's a small slot screw under there I would recommend a bit of wd40 before starting (the screw is soft) I cover the area with blue painters tape as you'll be working right against the paint work.
George S Patton
While you're doing this, take the set screw down to your local hardware store and get a stainless steel allen head set screw.  Don't quote me but IIRC it has 3 x.8 or 4 x .8 mm threads.  Stainless steel won't rust, and you can apply more torque to an allen head screw than a slotted one that's probably rusty with a boogered up slot...
My mirror has been floppy since before I owned the car.  I think the door skin around the cage nuts is bent.  The slotted screw is stuck and I haven't felt like attempting to drill it out, so I let it flop.
I went to RealOEM and they say the little grub screw is NLA but they do list the part number and Roger's Tii claims to have them for sale for $.95.  It is listed as a 320i part, but shares the same number as ours.
a20792913d28d7a983f106_m__07947.1417459354.1280.1280.jpg?c=2
The tip of the screw is tapered, so a hardware store set screw may not be an exact match.  I assume the taper mates up to a ramped end of the bracket that's mounted on the door, to pull it in tight.
It wouldn't be too hard to add that feature to a hardware store screw, if you bought a long enough one.  You could buy a nut and a screw with the same threads and cut off the screw's head, so you can chuck it up in a drill and then use a nut to hold the hex end of the grub screw to the end of the long screw and use a grinder to put a point on it while spinning it.  Just remember lefty-loosey -- righty-tighty, so the pieces stay together.
Edit- you might be able to put a point on a new set screw by chucking a cut-off allen wrench in a drill and using that to hold the screw, while pointing the screw up at the grinding wheel to shape it.
I was hoping the RealOEM site would list the screw specs, but no such luck.
Outside mirror
No. Description Supp. Qty  From   Up To  Part Number Price   Notes
01 Rear view mirror   1     51161801866     ENDED
02 Csk.fillister head srew AM4X22 1     07119901723     ENDED
03 Washer A6,4-ZNNIV SI 1     07119904202
04 Set tooth washer 25 A6,4 1     07509064287     ENDED
05 Hex bolt M6X10-8.8 ZNS 1   07/1977 07119913117 $0.40   ENDED
05 Hex bolt M6X10-8.8-ZNS3 1     07119904633 $0.20
06 Nut M4 1     07129925804 $1.09   ENDED
07 Exterior mirror left TRAPEZ 1     51161804452 $202.45
07 Exterior mirror right TRAPEZ 1     51161807702 $202.45
08 Grub screw   1     51161808536 $2.16   ENDED
09 Csk.fillister head srew M4X20 2     07119928439 $2.87
10 Seal seft TRAPEZ 1     51161807731 $12.80
10 Seal right TRAPEZ 1     51161807732 $12.80
11 Mirror holder   2     51161832567 $7.17   ENDED
12 Frame   1     51161807748 $18.58   ENDED
13 Mirror glass (driver's side) TRAPEZ 1     51161807747 $38.24   ENDED
13 Mirror glass (co-driver's side) TRAPEZ 1     51161807753 $38.24   ENDED
14 Exterior mirror right RHD 1     51161821794 $204.09
15 Mirror holder   2     51161832567 $7.17   ENDED
16 Seal seft   1     51161822061 $12.09
16 Seal right   1     51161822062 $12.09
20 Nut M4 2     07129925804 $1.09   ENDED
Notes
Edited by '76mintgrün'02
I honestly don't remember whether the ones I got had tapered ends, but...they've been holding both my mirrors on for 25 or so years; haven't fallen off yet 😁
So long as the end of the screw turns so that it goes under the tapered end of the pot metal bracket that's secured to the door, it'll grab OK.  And you can torque an allen head screw better than a slotted screw without fears of stripping the slot.
