Rear Axle Castle Nuts
paulyg
I'm rebuilding a set of trailing arms. After tearing down the old ones, I realized that the splines on one of the old stub axles were toast. I purchased two new axles. The old castle nuts seem to be a little sloppy on the threads of the new axles. Do they tend to be a sloppy fit? I know that the "new" nuts are not quite the same as the old ones (shorter).
2 hours ago, mosman58 said:
really should do the hub as well...
+1;  at least check to see if the hub feels loose on the new shaft.  If it is, not even that 275 ft/lbs of torque is gonna keep 'em tight...
...yeah, the hub is harder than the earlier milled shafts, but softer than the later
rolled ones, but either way, when the shaft is deformed, the hub has usually
worn, at least on the clamping face where it meets the outer bearing's inner race.
