Deciding on a good ground point in the trunk
Setuck
This is how my trunk battery is hooked up, has worked for decades.
76 BMW 2002 Arktisblau M42 5 spd - Born 5.21.76 - daily money pit
06 Aston Martin V8 Vantage 6 spd - garage queen *  73 Mustang Convertible 351C
15 VW Touareg V6 Executive - daily driver * 23 Audi e-tron SUV (wife's)
For battery ground, I bolted it to the brace that the trunk lift bracket because the battery is to the right side of the trunk and the power lead follows the right side of the car to the firewall in the engine compartment.
I grounded to the hinge bracket in the top corners of the trunk...sturdy 8mm stud there.
Me, I'd pick something a bit stouter than the sheetmetal of the floor.
Just because I've spot- welded, and it doesn't take all that much
current to make a nice spot weld to thin metal.
If the floor's best for your particular routing,
then, use a pair of backing washers to give yourself
more area, and remember that the more VOLUME of metal, the better it
will conduct.  So a couple of thick fender washers will do a pretty good job
IF they make good contact to the sheet in a large area.
