Building a chassis roller / rotisserie
Yojedi8802
I am in the midst of a full restoration of my '72 roundie.  Everything stripped and body now on jack stands.  I've drafted up  a  roller / rotisserie to build for paint stripping and rust repairs.  Design objectives are light weight and can be disassembled for storage as it's just a hobby use.  So far I've found at my local metal supply shop some galvanized steel square tube, 1-1/4"x1-1/4"-16Ga.  Would this be strong enough for my purpose?
16 ga  is only 1/16 in thick, I would definitely not be comfortable with that, it would lack rigidity big time.
Go thicker, even for occasional hobby use. Dont want it folding while man handling the shell around.
Edited by tech71
76 2002 Survivor
71 2002 Franzi
85 318i  Doris
Yup I would use 3/16 and you don't want to weld galvanized steel, the fumes are bad for you, and it's hard to clean the galvanation off on the inside and outside to keep it from dripping into the weld which will lead to poping and molten metal spraying on you.
George S Patton
   Would HR stee be a better choice?
Edited by Yojedi8802
My choise would be mild steel 3/16 and gusset the uprights and the width of the base the same as the car. I made mine to mount up to the chassis sub frame mounts. Remember the cradle not only needs to take the weight it also must keep things true.
Edited by Son of Marty
George S Patton
10 minutes ago, rstclark said:
Have one with mounts for  roundies or square tails in San Diego  I've used it and it works fine  PM me if you're  interested
It disassembles into smaller  transportable pieces
That thing looks heavy duty.  PM'd you
  • 1 year later...
