Torque Spec Question - basic
Pablo M
Go to solution Solved by Mark92131,
Now that I've been digging into the mechanics of my new-to-me '72 02tii I've been looking for torque specs and came across these below. I also have Haynes manual, but couldn't find a torque spec for the oil drain plug so went searching further.
My question is what does the +x and @1 mean? For example, the control arm connection shows torque to be 51 +14 @1. Does that mean 51-65 ft/lbs? Or something different? And what does the @1 mean?
@flagoworld posted this link in a thread:
r8QdPFuDQRtVZgb1mJUi4n1YaO7956tnGBkKmoMb
DOCS.GOOGLE.COM
11 - Engine Engine ,Tightening Torques Nm,mkp,<a href="http://lb.ft">lb.ft</a> Engine (block) to gearbox (transmission), M8,25 - 27,2.5 - 2.7,18 - 19.5 M10,47 - 51,4.7 - 5.1,34 - 37 Cylinder head bolts The following procedure should be followed on all repair work where torquing of the...
@Buckeye created this diagram in a post I came across.
2003 e39 M5 (daily)
1986 e30 325es (sons car)
  • Solution
@1 means Note 1, the car needs to be on the ground with 150lbs in each seat, a full tank and 46 pounds of luggage in the trunk on the left side.  The 51+14 are min/max in foot lbs for the nuts in question.  Some torque guides (like the one for head bolts) have an initial torque in ft/lbs and then a torque angle in degrees.  You use your torque wrench to set the initial setting, then a torque angle gauge to complete the final torque setting.
Mark92131
Edited by Mark92131
  • Like 5
1970 BMW 1600 (Nevada)
Quote
Joint disc attachment -14+2.2
Joint flange attachment -18+2.2
...but my torque wrench only goes to zero.
How do the negative torques work?
regen?
  • Haha 1
regen?
Mine goes to eleven.
Ray
