Seats…??
Readie
Critical measurements:
  • seat width--will it fit between the door sill and the tunnel housing?  An Audi doesn't have a tunnel housing, remember...
  • seat cushion height.  2002 seats sit well above the floor, while most modern seats are mounted directly on the floor.  You may have to cut your original seat mounts off the body and make a new mounting plate that bolts directly to the floor.
  • does the back tip forward?  If it doesn't, you'll have a heck of a time accessing the back seat.
I picked up these Recaro seats which has the tiny VW/Audi stamp on the bottom.  I have not idea what model/year but likely not as new as a TT.  They did come out of a 2002 with a mounting bracket affixed.  Plan is to put them in my 72 mostly because "they are not sport seats" and are about 3" wider at the shoulder for my incredibly superhuman upper body  fat A$$.
Edited by Steve Tochi
  • Haha 4
A lot of seat threads here. I found what worked best for me was the VW Jetti GTI seats (cannot remember the year).
Check the bottom for the 6 bolt holes. Some VW's have a mount that isn't compatible. The 6 bolts make it the easiest to mount into a lot of adapter plates here.
Old Fox body Mustangs have Recaros that may fit.
Corbeau makes some new recaro knock offs. Do not know the quality, but they are affordable. $700 a pair?
Check a lot of threads here.
Cheers!
what year TT? the first generation used the 3 mount positions that don't translate well to any other car. the later cars have a more traditional mount but would still be a hassle to put in. the TTRS recaros may have the standard 6 bolt recaro mount but I am not sure on that.
