How much CV wear is too much?
Mucci
I keep watching videos of CV rebuilds and everyone is very vague on acceptable vs unacceptable CV joint wear.
I got a set of axels second hand and don’t know their condition. I tore one down today to inspect. Let me know what you think of the wear:
The balls look flawless, which is a phrase I don’t think I’ve said before.
I did notice one axel shaft has blueing at the end. Is this a treatment or from overheating? Any concern there? Splines look ok.
Edited by Mucci
1975 2002 - US Spec, Taiga Green
Great, thanks for the feedback. I'll get the new boots and grease on there.
So what are the "too far gone" wear characteristics to look for during a visual inspection like this where I don't know the part history?
Also, is only one side heat treated? Is the axel directional because of that? I don't have it in front of me but I thought it was symmetrical.
Edited by Mucci
Too far would be like twisted splines, balls pitted/ not shiny, cage cracked, inner parts grooves has pits/ bits missing.
Axles are not directional from new i think. Some ppl like to maintain direction when they are used. I have not and the world didn’t end.
A good diagnostic is radial play in an assembled axle. Any more than a few millimeters front to back will began to be felt in the steering wheel when putting a load on the axles (e.g., driving up a hill at a freeway speeds) as a slow shimmy (slow compared to a bent or out-of-balance wheel). If the shimmy goes away when you crest the hill, that likely indicates that you have a sloppy CV. These can last for a long time before the slop reaches a critical mass.
Chris B.
'73 ex-Malaga
Oops. I was thinking of the effect on a front driver (my daily driver is a Jetta TDI). I don't know how a sloppy CV would feel on a rear driver, because I have always kept mine tight on my 02.
Chris B.
'73 ex-Malaga
