2002 1968 Restoration
RTHLSS1
On 7/23/2020 at 2:29 PM, RTHLSS1 said:
I am considering repainting it back to original Polaris or some modern silver color (Frozen or Silverstone silver).  Also I am considering making it black since I really like how chrome pops out on black color. Still have plenty of time to decide.
If you’re considering re-painting it silver, an original ‘02 silver — by which I mean Polaris metallic (060) — will generally add value to the car, whereas a modern silver generally will not. Your car is a first-year 2002. Down the line, many of those interested in a 1968 2002 will also be interested in originality.
Besides, Polaris is great color. I bought my ‘76 new and have never regretted my choice of color... in contrast to some other decisions I made in the '70's... ??
  • Like 4
3 hours ago, Mark92131 said:
Your in luck, the FAQ has a very nice Blog section and super easy to setup and post.  Just click on the Blog link on the top line menu on the FAQ and "Create a new Blog" from the Blog page.  Then you can add your restoration photos and stories as you go.
Mark92131
@Mark92131 @AceAndrew check it out https://www.bmw2002faq.com/blogs/entry/2124-2002-1968-story-so-far/ But question is than why have blog and this thread at same time ?
3 hours ago, AceAndrew said:
Yes, please start a blog on the car, extremely easy to do here on the FAQ.  In addition, it'll make referencing your car in the future much simpler.  It is a neat car.
Also, another request to see if you can save the early chrome dash.  That style dash reflects the original design intent of the 2002, much nicer than later dashes.
https://adamsautosport.com/information/tutorials/bmw-2002-dashboard-variations/
Dash stays it is really nice once sorted up - thanks for advice. Chrome on mine dash is peeling and nothing is aligned right
1968 E10 2002 / 1972 E9 3.0 CSI / 1985 E24 635 CSI / 1988 E30 318is 2 door / 1989 E30 M3 / 1990 E30 325i 2 door m technic 2 / 1994 E36 cabrio M3 S50B32 swap / 1995 E31 840i 2X / 2004 e46 M3 coupe / 2011 335iS / 1991 SL500
https://www.e9coupe.com/forum/threads/1972-e9-3-0-csi-chamonix.27406/
https://bigcoupe.com/phpBB3/viewtopic.php?f=25&t=32783
IG: @pod_rzaj
2 hours ago, Conserv said:
If you’re considering re-painting it silver, an original ‘02 silver — meaning Polaris — will generally add value, whereas a modern silver generally will not. This is a first-year 2002. Down the line, many of those interested in a 1968 2002 will also be interested in originality.
Got you. If I will go with silver Polaris will be my choice.
Amazing to see e10 from first owner ❤️. Respect to you!
IG: @pod_rzaj
Today I applied dry ice on the floor to check out if bitumen removes easier when frozen. I took 30 kg of dry ice and put in several bags for easier placement and ability to move it. Left it on floor for 1 hour and the floor panels and then try how it peels away. Floor actually freeze from bottom.
I was able to remove big chunks at once so I would definitely suggest to anyone who will be removing bitumen from floor. On my e9 I used hot gun and chisel and it took ages with a lot of mess.
I found several holes in floor panels after removing bitumen from top and bottom side.
IG: @pod_rzaj
We removed thick layer of bitumen from inner wheel walls. Found previous repairs were and some rust as well.
Also holes were hiding on both rear axle supports.
Grind of bitumen continues so good 20kg of bitumen was removed.
  • Like 3
IG: @pod_rzaj
On 7/30/2020 at 2:58 AM, Hans said:
I would have put a few Pivos in the ice. Where in Slovenia?
Seems that rust is prevalent there too.
Good thinking ;)
Car was from area where there is not so much salt on roads in winter time but after 50 years it was expected that there will be rust since it has been driven a lot.
IG: @pod_rzaj
Subframes were sandblasted and dipped in anticorrosive coating so that all hollow parts will be protected. Next stage is powder coating for final finish.
Engine is out and I started taking exterior apart.
New floor panels and rear axle supports arrived from W&N
Edited by RTHLSS1
  • Like 3
IG: @pod_rzaj
32 minutes ago, RTHLSS1 said:
Good thinking ;)
I've been to Slovenia a number of times. Very nice!
Nice. Relatives in Slovenia or just traveling?
IG: @pod_rzaj
Cleaned as much I could - rest will be grinded of once new floor will be welded in.
IG: @pod_rzaj
Just travelling - usually through  en-route north or south.. Been there 5 or 6 times. Pretty much seen the whole country. Great variety and some good mountain roads. Where are you?
Small country but we have almost everything to see.
I am 10 km out of capital - Ljubljana.
IG: @pod_rzaj
We removed remaining trim and windshields.
New rust spot/hole was found hiding under passenger side pop out window.
Subframes and its parts were painted.
Rear axles were restored.
IG: @pod_rzaj
3 hours ago, RTHLSS1 said:
Sorry but that's just painted  - restored is different.
Your nuts are wrong and if they've blasted what they have painted your stub axles are nuts. The part where the seal is should neither be painted nor blasted - it will eat your seals within a few kilometers.
