Wrong heater hose??
rapandi
Go to solution Solved by Simeon,
I just received my order from WN and one of the items I ordered was the heater hose going from the engine to the heater valve. (RHD 2002TII)
OEM part number is 64211354599. I emailed WN prior to ordering and quoted this part number and they responded saying that they have them in stock.
If you look at the hose they have sent me, it is nowhere near the shape that is shown in REALOEM (part #2). Or do they just come like this and then have to be stretched out?
post-49135-0-62152800-1452517454_thumb.j
post-49135-0-99683600-1452517495_thumb.j
post-49135-0-38397200-1452517526_thumb.j
Am I correct in saying that this is the wrong hose? I have never had WN send me the wrong goods so I am kind of doubting myself here and hence this posting...
By the way the width of that hose from edge to edge is approx 200mm. Internal Dia is 18mm.
Raj
Edited by rapandi
Raj
1972 BMW 2002 Tii - Golf Yellow
Realoem & bmwfans.info online parts catalogs are somewhat generic, in that the BMW-sourced diagrams might not match the actual part configuration.  I have not had the occasion to research RHD parts, so don't know if there are entirely different diagram sets for RHD vs. LHD part numbers.
Perhaps you can provide W&N with a photo of your existing part to confirm that they sent the correct/incorrect hose.
John in VA
The hose in the picture looks like the one from the intake manifold to the heater on my US 1972 model. The one from the back of the engine to the heater valve is shaped like the diagram.
I lied before... that isn't what it looks like.  I think the one you are looking for comes from the back of the engine to the heater control valve?
Mine looks like this on USA model: http://bavauto.com/assets/imglib500/64211353368.jpg
Hope that helps
Edited by garya
The '02er formerly known as Gary in Colorado.
Garya - That is exactly what I thought it should look like
John - the PO blocked the water port and basically got rid of the hose connection from the engine to the heater. So I don't know what the hose should look like apart from what it shows on websites like realoem etc.
I am going to write to them asking if it is a mix up.
Thanks
Raj
What year is your '02?
As I'm sure you know, there were two different heater cores and thus two different heater hose sets used on 2002s. Early cars had smaller diameter nipples on both the heater core and the engine, so the hoses were smaller in diameter.  Later cars used larger diameter hoses, and when the two barrel manifold was introduced, the return hose (on the engine's left or intake side) was shaped differently. This may be what's causing confusion on your car.
If you can find a factory parts book to peruse, you should be able to identify the correct hose for your car's VIN--unless of course a PO has bodged things, like installing a later heater in an early car...
Let me get home and I will scope out my hose Raj. I can't see how RHD would be any different. Usually Realoem correctly addresses RHD cars if you have entered your car details up front so would identify if there was a difference by only giving you the correct RHD part number (even if the diagram may not be correct).
rtheriaque wrote:
Thanks Simeon.
I honestly cannot see how RHD can be any different either.
Here is a pic of what this hose looks like on my engine. Notice how it swoops down in to the bell housing area. There is no way this hose can fit if the engine and transmission were in the car.
I have written to WN. Just awaiting their response. In my correspondence with them I requested pipe with part number 64211354599. I remember WN saying they have the correct hose and would send it to me. They usually don't stuff up like this. So either I have it wrong or they have it wrong. I am just making sure I have not stuffed up.
post-49135-0-09422900-1452587526_thumb.j
Look closely and you can see this new hose interfering with the return hose from the heater to the engine block.
Raj
I've just looked at my rhd may/73 tii and the inlet hose looks exactly like #2 in the diagram and like garya's bavauto hose.
The return hose is different from the diagram, but nothing like the WN hose.
Does the WN hose have a BMW part number on it?
post-35003-0-57716500-1452589116_thumb.j
Edited by JohnH
02tii 2751928 (2582)
Hmmm having looked at the hose on my March '73 car, I would say it was the right hose. My hose has 90 degree bends at each end and a section that runs horizontally before dropping down and then running back again in the same direction where it then runs into the back of the head. The diagram looks like it would almost go 'diagonally' and take the shortest route between the two ends.
Not that easy to see:
post-39712-0-39436200-1452590307_thumb.j
Edited by Simeon
  • Solution
Thanks Simeon.
From this picture, rotate this clockwise about 90 degrees and it will be about right.
Thanks Simeon.
Bare in mind that the tii uses a different hose. See parts catalog extract above.
It would seem that WN sent a carbie hose.
Aha! That could be it. Mine is carb of course.
Simeon I think you are right!
I couldn't have worked this out without your picture and the fact that I don't have the hose from PO.
Thanks mate! I guess the REALOEM schematics aren't always a true representation.
post-49135-0-21730300-1452591845_thumb.j
Raj
