Touring 250Mm Rear Drum Different Than 320I Drum?
Go to solution Solved by LarsAlpina,
If it was used with the 2002 hub, it probably wasn't hubcentric on the touring.
But that shouldn't prevent you from using one.  Wonder if the shoe width and position is the same.
The E21 part is cheap- order one and see if it works!
no help here,
Is the stock 250mm drum on the Touring different than the 320i drum that people use on rear big brake upgrade? Do these parts interchange? Thanks!
As far as I know, all Tourings (except 1600) had the same 230mm brake drum as the sedans (part# 34 21 1 101 741)..my Touring does anyway.
The Turbo had the 250mm drum (part# 34 21 1 117 047)
Edited by 02Les
Les
'74 '02 - Jade Touring (RHD)
'76 '02 - Delk's "Da Beater"
FAQ Member #17
Only Neu Klasse & Turbos got the 250mm drums
2002s all variants (plus 1502 & 1802) got the 230mm *see pic
and 1600-02s got 200mm
If you car has 250mm drums on it now, then a PO has probably done the E21 rear brake swap.
All E21 drums were 250mm also.
HTH Beaner7102
post-32211-0-54980700-1395889563_thumb.j
however the Haynes manual says Tourings have 250mm drums. Not saying it's correct. here is a photo
Haynes also shows the 1500-1600 as 250mm, so I think there is two errors on that page.
The info I posted is from the BMW Original Parts Catalogue, which I would believe over Haynes.
Have you measured your drums to confirm they are indeed 250mm? Best confirm that, then look for the correct parts.
Beaner7102
250mm part numbers #34 21 1 101 787 & #34 21 1 117 047  -  have been replaced with #34 21 6 752 373.
Which are the same number the E21 & NK part numbers.
So Yes E21 250mm drums will fit.
HTH Beaner7102
  • Solution
There are two errors on the Haynes page but what´s wrong with 1500-1600 NK Sedan being described as having 250mm drums? Those cars in fact had 250mm drums.
Error 1: Touring never had brakes any different from Sedan with the same engine. 1,6L always came with 200mm from factory, all others had 230mm.
Error 2: 1502 had 230mm drums with different wheel cylinders and no 200mm.
Regards, Lars.
Ei guude wie? (Spoken as "I gooooda weee" and hessian idiom for "Hi, how are you?")
Já nevím, možná zítra.
