Fun With Diff Ratios, Rpm, Tires, And Speed
gliding_serpent2
Here is some FYI info on ratios that may helped me get an idea of the effect of tire size and diff ratios, on speed and rpm.  I did these calculations to help me manage expectations at the track and to compare my current setup options, and help me plan future options.  After my first driving course with my Tii on our local tight track I was able to get an estimated 90-95mph on the back straight in fourth using the "street cruising setup" below.
Classic stock:
1:1 transmission ratio (4 speed in 4th)
3.64:1 open diff
Michelin XAS 165/80/13 tires (22.4567 inches diameter, stock size)
6000rm
110.1mph
Street "cruising" Setup:
3.64:1 open diff
Falken 615K 195/60/14 tires (22.28 inches diameter, 0.77% smaller)
6000rm
109.3mph
Track setup:
e21 3.91:1 LSD
6000rm
101.8mph
Autocross/Track setup:
e21 3.91:1 diff
Toyo R888 205/60/13 tires (21.78 inches diameter, 3% smaller) I do not have these tires.
6000rm
99.47mph
Autocross setup:
e21 3.91:1 diff
Toyo R888 185/60/13 tires (20.87 inches diameter, 7% smaller)
6000rm
95.2mph
useful links...
http://www.carbibles.com/tyre_bible_pg4.html
http://math.about.com/library/blcirclecalculator.htm
http://www.csgnetwork.com/speedcalc.html
Edited by gliding_serpent
1973 2002Tii (Pacific Blue)
1984 911 3.2 Carrera (Platnum Metallic)
2009 328xi (Black Sapphire Metallic)
2010 Mazda Speed3 (Black Metallic)
Interestingly, I went to the drag strip this past fall with a tired original motor and a 32/36.  My 1975 (8:1 compression) with the e21 5 speed and 3.91 LSD had a best 60ft. time of 2.443 seconds on warmed up Yokahama SDrives. I went through the trap in third at about 6k rpm at 77 mph.
(O=o00o=O)
williamgruff posted a spreadsheet a while ago that had every transmission, all their ratios, all the possible diff ratios and the resultant speed in any gear at a range of rpm's. quite handy for reference.
for me steet/cruising is a 4.10 diff. race car is 4.44 diff...120mph at nowwhere near the 7500rpm redline on 205/50 15's.
Seems like a good plan.
:P
Ray
I agree about the OP's sizes being off.  Not sure what formula he uses (and there can be slight differences between manufacturers) but I've always used the formula of : width (in mm) x 2 x aspect ratio % divided by 25.4 (mm / inch) + the wheel diameter = tire diameter.  Thus I get 23.4" for the OE tires, and 195/60 x 14s should run about 23.2"  I run 185/60 x 14s which have a dia. of 22.74".  A little smaller than stock or 195/60 x 14s but I had North Hollywood Speedometer re-calibrate my speedo when they had in their shop for cleaning.
Bob Napier
