Schrick 292 Cam Install
jdeitch
About 750$
Close on price. Cam was purchased here on FAQ with 'wanted to buy' post.
Nice stuff!  Did you also purchase new rocker arm shafts?
Within spec. Chucked mine up in the lathe to polish. Good as new.
1975 Polaris 2002 (RAT 02E), 1962 mini Cooper S
1994 Land Cruiser - expedition vehicle, 2012 VW Touareg TDI.
2002 restoration blog - http://rato2e.blogspot.com/
FYI, make sure all the threaded head bolt holes are clean and free of any oils or fluids.
+1 on this (shop towel, paper towel, brake or carb cleaner, QTip, etc).  Use a shop vac to help remove debris from the combustion chambers and bolt cavities.
Hard to tell - but make sure the timing chain does not fall into the front cover...
Looks great!! Is the a copper brush?
It's actually a plastic cone brush.  I use it for tasks like this where I don't want to damage the underlying surface.
Yes to all of the above.  Cam chain is zip-tied around gear... Not going anywhere. ;)
Wife lapping valves. (She's a car person too!)
post-39742-0-08113200-1381760458_thumb.j
New HD single springs from SCHRICK
post-39742-0-55043300-1381760559_thumb.j
post-39742-0-17225300-1381760613_thumb.j
New HD rockers and shaft locks from IE
post-39742-0-11561500-1381760645_thumb.j
Head back on block. IE intake manifold and stainless steel water bypass pipe in pic too
post-39742-0-57967900-1381761054_thumb.j
Setting torque angle on head bolts
post-39742-0-25080500-1381760745_thumb.j
Edited by jdeitch
