Bubbles In Kfish Injector Hose.
Cris.MTL
hey guys,
So I noticed that they are air bubbles in the fuel injector hose #1 from the Kfish to the injector while the car is running, I checked the hose connections and they are all tight.
Any idea what could be causing this or where I should start looking?
Thanks
The kpump is a positive displacement mechanism, so air in the output lines suggests to me it is/was sucking air on the inlet.
Suggest you place towels around the #1 injector and carefully loosen the line at the injector end.  Fuel will bleed out, perhaps and hopefully taking the air with it.  Then see if it recurs.
I've never seen any bubbles in those lines, but I can feel the pulsations when I put my fingers on them.
It does sound like you are leaking air into the pressure side of the line.  Have the sealing rings ever been replaced?
I ended up figuring it out last night, at least I think I did.
At first I cracked the line open as the car was running as per the Kfish manual states but there was no fuel leaking which I found strange. I then shut the car down and removed the line and the delivery valve, cleaned it up and reinstalled it. I fired up the car again and repeated the same test, loosen the hose fitting and check for fuel, at first once again no fuel leaked out but i decided to gently wiggle the hose and give the valve a bit of "love" and that did it. It started to leak fuel, I tighten the hose fitting and the air bubbles were gone,
Essentially I bled the line and now I have no more bubbles.
I don't know when the sealing rings were replaced last but to me it seems as if it was not seated properly at first. Would those sealing rings be available anyways?
Just a reminder that the seals are supposedly "one time use" crushable steel.  I have had the problem with leaking fuel from the fitting due to an overly flattened seal.  No amount of tightening (watch it) would stop the leaking.   Now I keep a spare set.
73 Inka Tii #2762958
