Electric Fuel Pump Installation Instructions?
Hokie09
1 hour ago, John76 said:
I would be concerned about using the "45 year-old, brittle, plastic" gas line running through the passenger compartment with even a low-pressure "pusher" fuel pump.  It's okay for the stock "sucker" pump in the engine compartment, since it would only suck air if it cracked....not spit gas.  Blowing up the trunk is one thing....blowing up the passenger compartment would ruin your day!
Well said. Plus, the plastic gas line doesn't have a flared end to prevent rubber hoses from spitting out the line, thus causing a major issue.
Well to be fair, the metal return line isn't flared either.
George S Patton
True - that's why I ended up installing and flaring new line. I considered just scoring some deep grooves into the existing line w/ a dremel, but ended up replacing the whole line.
