Where to apply RTV on a 2002 engine?
I'm in the process of entirely re-gasketing my new (to me) '75 2002 motor with the exception of the head gasket, which appears to have been changed. So basically front seal, Rear Main seal, exhaust studs, distributor housing gasket, timing cover gaskets, rear crankcase seal that goes behind the RMS carrier, valve cover gasket, oil pan gasket and the oil filter housing gasket (I'm probably forgetting some)
Where, if any of these, should I apply RTV silicone? I did the distributor housing on the old engine with just the gasket and never had a leak.
1974 Malaga 2002 4282899 "Little Red"
1976 Polaris 2002 2374061 "Rusty Shackleford"
1998 Dk. Blue Volvo S70 T5 "Carlene"- 221k Miles
There are very few places where BMW recommended gasket sealer originally. If your parts are straight (not tweaked or scratched up from a previous re-build attempt, and you didn't have leaks before, I would stick with the original directions to put some non-hardening gasket sealer at the intersection if the timing case covers and head and valve cover gaskets and assemble everything else dry.
I put it only on the timing cover corners. But you could do it how my diesel truck is put together. RTV everything! Not shitting you the only thing not RTV'd is the intake and exhaust manifolds. As long as you use something like Permatex orange you'll be fine. But my 02 motor is fairly dry on just gaskets alone.
So really it all comes down to the engine builder and the engine. I'd say if you wanna be conservative like the others mentioned just do the corners of the timing cover and you'll be OK
-Nathan
What everyone else said.
My rule of thumb is to put it on any crack-
like where the oil pan crosses the timing cover and rear oil seal cover.
It doesn't take much, and things never leak after doing that.
I also use it on the valve cover gasket transition from the head
to the front cover, and if you're VERY careful the first time you pull
the cover, you can then reuse the gasket with impugnity.
I use it as an installation aid on the front and rear main seals, too.
No good reason other than it's nice and slippery, then sets up solid.
Took apart a Toyota 3FE- I had to bash the oil pan off, they'd glued it on so well.
'Course, they'd also installed the camshaft with a sledgehammer...
Everything is pretty straight on this engine, looks like it hasn't been opened up in a long time- all of the old gaskets were a major pain to get off.
I will be doing the dab of RTV at the intersections and no more.
It was by no means a "dry" engine, however..
When I picked it up:
Everything cleaned now:
I will be using the later roundel valve cover off of a junk engine I have, hopefully that will not present a source for leaks. I just like that look better. Gaskets get here Friday and engine should be going in Saturday if I have the hoist.
I did the same thing, dry gaskets all around. Leaked like a sieve around the front timing chain cover, so I dabbed at the corners. Still leaked. Ended up RTV'ing the whole perimeter, as well as the valve cover. No leaks anymore, but I must be doing something wrong.
i know i am, i'm sure i am...
Did you torque all of the bolts correctly?
Speaking of those, does anybody know the torque specs for the RMS carrier and the Oil Filter Housing? I was unable to find those anywhere in my Haynes manual.
and it is important to attach the bolts in the right order. for instance, upper timing chain cover vertical bolts go in before the horizontal ones.
