magnetic drain plugs
c.d.iesel
magnetic oil pan drain plug...haven't seen another--at least on later cars.
Anyone have one that was factory installed?
I used the super inexpensive way of converting the drain plugs in our cars to magnetic. Bought some small, incredability strong neodymium magnets and placed one in the cavatity of our existing drain plugs, and, bingo you have a magnetic drain plug.
I think the tip came orinigally from Mike S.
Bob Napier
what did you do > epoxy it in there? got any more? or a source?
1970 Agave work in progress
Born on May 14 1970 and delivered May 19th 1970 to NYC to Hoffman Motor Corp. Agave code 071
new guy
help appreciated!
other cars: 1991 318is / 1999 540iT
the bmw motorcycles 1950's - 1980 come with magnetic
plugs in the gearbox, rear diff. Easy to add to the motor oil drain.
Some BMW cars manual gear box and rear diffs also come
std with magnetic plugs. Many sizes.
Every motor and gear unit should have one
look at the site link above - any size you need they have
The early longneck diffs had magnetic drain plugs, some early sideloader diffs as well. They're the same thread as the later diff plugs and the 19mm head engine oil drain plugs. 10mm Allen like non magnetic diff plugs. I have one for the oil pan of my Red... Also a vandalism deterrent as very few ruffians have 10mm Allen wrenches on them, but most may have a 3/4"-19mm wrench. ;)
Tom Jones
Be careful if you just add a magnet. If it falls off, it could cause a problem. Your magnet has been gathering metal shavings and all of a sudden the big clump of metal is set free and can go anywhere. That can cause a much bigger problem than a piece of metal here and there.
Carl
1969 1600 Cabriolet Ti engine
thread size of M22 X 1.5 ? for all 2002s '68 - '76 ? anyone? Beuller?
new guy
help appreciated!
any1?????
YES mostly; some later cars and most replacement oil pans have drain plugs with 12x1.5mm threads
My 69 (built 26th April 1969) has a magnetic plug too.
I'm the fourth owner however, so I have no idea if it's stock or not.
Which one?? Engine, trans or diff??
BTW, nearly all BMWs have magnetic trans drain plugs.......
Tom Jones
You don't have to worry about a neodymium coming out of the inside of a drain plug. If you've never been around them you'll be absolutely amazed at how strong a magnet they are. I tried to get one out of the inside of the drain plug on my car and it was a major job, even though the thing is only about ¼" long, and smaller in both the other dimensions. Trying to pull two of the little buggers apart takes a lot of strength. They are incredible.
I don't remember where I got mine online, but just google it and you'll find lots of sources.
Bob Napier
Clarification: my 69 2002 has a magnetic engine oil pan drain plug. Mike above was asking if anyone has or had seen another.
