clarification on big brake parts.
Turb02
Im sure this has been covered but when reading the FAQ about the parts required for the standard 2002 brake upgrade, all it says is "mid 80's 240 with vented rotors".
Looking on Rock Auto there isnt "just" a 240. for example selecting the year 1985, I get these options in the 2xx range: 244 GL/DL/Turbo and a 245.
Can someone provide a solid year and model?
On the same topic, has anyone used the IE E21 hubs? Thoughts? Pros/cons?
Thanks everyone.
75 2002 "Project Turb02"
95 Hellrot M3 *Sold
95 332is *Sold
We can't tell you.
Because it varied.
Any 240 COULD get the vented brake- I'm sure it was an option
on the sales slip- but it doesn't follow the more general designators.
Pleasantly, if you have a caliper for a vented brake off a 240, it will
work just fine.
So, sorry, no, can't clarify that any further than to say that
AUTOSPECIALTY / KELSEY-HAYES Part # 4121008 Remanufactured
Front Left Rebuilt Caliper 38MM - VENTED
will work
and
BECK/ARNLEY Part # 0760446 More Information About this Part
[Front Caliper, Remanufactured]; Right;ATE Calipers;Solid Rotors
will not. Well, unless you use a solid 320 rotor!
That's how this one works. Probably would drive BMW engineers up the wall.
That's the Swedish way!
So it doesnt matter what the nomenclature of the 240 (244/245) is, as long as it used vented rotors?
Thanks for that bit of info! Seems cheaper to piece the kit together than to buy one from IE or aardvark or any other place. Would my assumption on this be correct?
95 Hellrot M3 *Sold
95 332is *Sold
Nope, doesn't matter. Do get one left and one right, tho!
And yes, I found that I could do it myself and save.
Don't forget the .070" spacers to center the calipers, either.
" tii " brakes are all you need .
Even for my goals of 300whp? That's impressive.
maybe not but you didnt mentioned 300hp goal anywhere. thats not very conservative and informative to start this way.
i have a modest 280hp in mine, 240 vented volvo calipers, rear VW gti set-up Alfa GTV6 MC, hawk pads all around, 205's tires. car can break your neck both direction.
1985 XR4TI, 22psi ±300hp
Any more I'm not sure you'd be able to replicate the kit for cheaper using all new (exept for refurbed calipers) for less than the IE kit. Considering the cost of Calipers/rotors/pads/new hubs/bearings/hub dust cover/12x57mm studs/little set screw + shipping from multiple vendors + the cost of redrilling/filling the calipers (optional, I know, but if your comparing apples to apples, this is part of the IE kit).
If you can piece it together for cheaper, and willing to spend the time, then by all means.
As for the IE hubs, they are a replica of the E21 small bearing hubs so I'm not sure what your asking.
Got these bad boys ready to go on in the next couple weeks (little too much lock-tite)....
you got a lil happy w/ the loc tite?..!!!.lol...looks like rasberry filling
As stated before any vented volvo 240 calipers work except the late 92-93 abs calipers. Get the girling ones, volvo ate vented calipers don't have any aftermarket and hardly any OEM.
It's pretty cheap to piece together the kit. I've picked up the calipers/hubs for $50 from a yard before(lemons car).
Calipers rebuilt + new pads ~$120
Used 320i hubs + new wheel bearing kit ~$80
320i rotors from blunttech ~$70
two washers $0.50
optional
SS braided lines from summit $60
wheel studs from IE $22
Thanks everyone for the info. As for the hub reproduction, I was looking for how the fit and finish is? When I saw them today...been offline for a while, I wa shocked at the price and that someone actually reproduced them.
95 Hellrot M3 *Sold
95 332is *Sold
