M2 madness
M3M3
finished up the modifications to the rear subframe today.
got the adjuster brackets welded on.
i beveled the corners to allow more surface to weld.
then, measure 4000 times, weld once..
it was a beautiful day for working outside.
outer toe adjusters
inner camber
then worked on the trailer tie down points.  using two tie down eyes from Turner Motorsport that are designed for use on E30 and E36 rear shock mounts.  mounting them with bolts to the bottom of the diff carrier.
one test fit.  using 12x1.5 bolts.  yes, there is room inside to get a nut on the bolt, and a 19mm open end wrench will fit in the slot from the rear.
after i get the car in the trailer and strap it down, i will mark the resulting angle of the eye and possible weld them to subframe.  for now the bolt will allow me to "adjust" them.
after wire wheeling the loose rust spots and welding lag, sanded with 220, washed with acetone and got out the paint
two coats later
now....some assembly required.  have to put bearings in the trailing arms, assemble subframe, then remove the current subframe, put this one in, and do an alignment.   hmmmm. not quite done yet.
2xM3
Jim picked up the tii trailing arms from the powder coaters...they look way better that the subframe..
installed the new stock rubber bushings with the press
then test fit on subframe.  whoooops.  so much for the nice powder coat.  the adjuster for camber is too tall and square, preventing the TA from swinging very far before hitting.  definitely not enough range for actual use.  scratched the heck out of the TA powder coat.  had to get out the grinder again and mess up the subframe finish.  argh.
2xM3
loaded up the trailing arms with bearings and grease and started taking apart the subframe on the car..
with e-brake on, was able to break free the hub nuts.  then used puller to draw the hubs off.
a great use of a cheap spare half inch socket extension...pushing out the stub axles.
ooops!  looks like my trailing arm exploded!
sorry for blurry cell phone pics...had grease on everything, maybe the lense too.
2xM3
back at it today....after making sure the heat was on in the shop!
got the tie downs mounted to bottom of subframe
pinched off the rear brake fluid feed to cut down on the draining when the subframe is dropped.
lines disconnected
calipers off
where did the subframe go?
there it is!
started assembly of new subframe.  DS TA on, stub axles and hub attached.
carefully measured the adjusters to get them in equal and "neutral" positions.  marked with hack saw for reference point.
hope to finish assembly and install tomorrow.
2xM3
subframe reassembled
these are the GC bottom perches i will be using.  note the more forward spring perch location.
subframe raised into position
here is one change IE should make to the kit.  the bolts need to be a few mm shorter.  hard to see in this pic, but the end of the bolt is about 2mm from car body.   the bolt length is also an issue with the inner side of the DS TA.  the bolt will be very close to the exhaust.  I may have to take the bolt back out and grind it down a bit.
tie down eyes
shot of the spring perch alignment. much better with lower moved forward a bit.
one of the diffs goes back in next, and I will replace all the cv joints on the halfshafts.
2xM3
 Where does the shoulder end / the threads start on the provided bolt? They may have been trying to get a full bolt diameter through the entire assembly and use an off-the-shelf bolt.
J Swift
Global Formula Racing (Oregon State University)
1972 Opel GT "Mae"
