engine installation attached to subframe tips needed
MarkB
Howdy,
Can folks chime in on a general procedure for installing the engine/tranny while attached to the subframe?
1) Do you install with wheels and struts attached?
-Do you remove wheels? I thought it might be easy to 'roll' the assembly under the car
-remove struts?
2)Do you use a combination engine hoist from the top and jack from the bottom, like in the tranny area?
3)Do you have the tranny bracket installed on the transmission prior to offering it up?
Any other tips / techniques?
Thanks!
Mark
Mark B
'67 2000CS
Unless you have the car jacked up high or have a pit, the engine on the subframe will not clear to go under the car.
I laid the engine on the side on a cardboard and slid it under, then hoisted the engine from overhead, slid the subframe under and set the engine on the subframe to the mountss.
Then I hoised the whole thing up and bolted to the rails.
Leave wheels off, but keep strutts on.
I would attach tran to engine before sliding under, save you lots of grief. Engine/tran center of gravity will be back a wayx though.
I did it with the car jacked up (doesnt really have to be that high, esp with the wheels off.
I had the struts tied together towards each other with rope, and the engine on a motorcycle lift. It slid right under and I lowered the car slowly while the engine sat low to get the angle correct. Dont forget the steering coupler!
76 Jade Green w/ E21 2.0 - DCOE Weber 40s, 304, 5spd, Stahl>Ansa, Wilwoods, H+R and Bilsteins, and some other fun bits.
I had the transmission and guibo installed but not the trans mount bracket, that was easy enough to get on. I had the headers and exhaust off the engine. Once I got close I had to jack up the transmission to get the engine more level. Its all about alignment getting those subframe bolts to line up, but once they did it was a piece of cake.
Looks a bit like this if you keep the whole shebang connected. Note: your experience may require fewer hunchbacks, more hair, and a more suitable location than a driveway.
williamggruff
I've used this same method, and it worked pretty well.
Matthew Cervi
'71 Bavaria
'18 M2
