How much oil does it take to do a complete oil and filter ch
jrhone
4.25 gallons I think but my favorite tip is to slacken off the oil filter using your favorite method and then unscrew it by hand while holding it within a large plastic bag. this will save a hell of a mess.
Actually, that is liters...
But in the US you buy oil in quarts. So buy 5 quarts - fill it till it hits the top line on the dipstick. Use 20W-50... or if you can find it, straight 50 weight. But whatever, you'll figure it out.
YYYEEEEEAAAAAHHHH!!!!!
Uh, a modification here - five quarts total should do it; but fill it until the dipstick registers full, then carefully start the car (I crank the thing over with the coil disconnected so that I can be sure that the fresh oil has found its way into the engine's vital parts, then reconnect the coil and start it). Let it run for a minute or two. Shut it off, check the dipstick again, and fill as needed. What you probably will find is that the level is down a bit due to the volume required to fill the filter.
-JFT
'68 1602 I wish I still had
No 2002 yet, but looking
2003 E39 sportwagon
1982 Porsche 911SC
Hi,
for a regular oil change i use 5 quarts
of 20-50. use a good filter like purolator
pc201 or mann. when you install the filter
fill it to the top and then put it on the engine.
don't start the motor with a dry filter.
you can crank the motor untill the oil
light goes off, then start the motor.
good luck
stone
stone racing co
phila pa 19123
Don't overfill the engine oil, just use the correct amount like BMW states in the owner's manual. Half a quart over is probably not going to hurt a lot, but overfilling is bad for windage, and can aerate oil.
4.25 liters = 4.50 quarts = the correct amount of oil when filter is changed (always change that filter, right?)
Unless you have dented the oil pan, the engine will have the right level of oil when you add the 4.5 quarts, run the engine to warm, turn iit off & allow it to drain back into the sump. If your dipstick is off, then your dipstick is wrong & you need to make adjustment for that.
When you calibrate your dipstick, you do that by adding a known amount of oil and scribe new lines, or make adjustments in the dipstick tube to have the markings match the oil, not the other way around.
Hot engine oil expands, be sure you are comparing levels the same way.
At work, oil drains & fills are measured by weight during engine development. A quart of oil = about 1.82 lbs, and since most of my oil changes at home are also done with product in larger containers, I use my refrigerant scale to weigh the gallon jugs. Using mass allows you to easily account for how much drains out, and you weigh the old filter, subtract the tare weight of the drain pan & dry filter. You only need to do that if you are tracking oil consumption.
…(I crank the thing over with the coil disconnected so that I can be sure that the fresh oil has found its way into the engine's vital parts, then reconnect the coil and start it)...
…you can crank the motor untill the oil light goes off, then start the motor…
Uh... sorry guys, but this is NONESENSE!
Think about it... what you're advocating is spinning the 'dry' motor on the starter to avoid spinning the 'dry' motor via combustion.
The motor is not 'dry' at all - there is already an oil film present on all the internals.
It may sound same-same, but actually cranking on the starter will prolong the system filling and pressurizing because the starter cranks at much lower RPMs than idle speed. The oil pump is RPM dependent to reach max flow and pressure - the faster it spins, the faster everything is back to normal. I don't advocate running at RPMs higher than idle for long, but idle speed is better than starter speed.
It is virtually the same as starting the car in the morning or on weekends - do you disconnect the coil when you do this too? Is oil pooling in the sump after an oil change/fill any different than oil pooled in the sump before a cold start? Gravity pulls the oil to the sump after shutdown the same way it does before you drain it for an oil change or you wouldn't be able to drain it all (most) out.
...when you install the filter fill it to the top and then put it on the engine. don't start the motor with a dry filter...
This IS sound advice - to pre-fill the filter to avoid any delays in floating the crank.
But, starting the engine, with an oil film already present for such a short time poses little, if any, risk of bearing starvation.
Cheers!
1976 BMW 2002
1990 Porsche 964 C4 Cabriolet
A sulphur or rotten egg smell is most closely associated with gear oil or ATF. These include sulphur compounds in their mix to resist compression when between the gear faces.
Are you certain that you didn't mix up any of these? Is it possible that what you smelt is coming from the tranny? Maybe a leaky seal?
Cheers!
1976 BMW 2002
