Transforming a 2002 into a E36- The build
rot62
I decided to modify the sump, so it was time to move onto the engine mounts. I needed to make to new mounts on the cross member as the standard mount holes were to close to the chassis rails. Also new mounts for the block were needed as well. The rubber engine mounts are for a skyline . In the second picture you can see the cut out in the sump so the engine could moved forward.
  • Replies 148
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Also today I got the pedal box mounted up. Due to a design fault (made by me) the clutch master cylinder didn't have a enough room to get the cap off (to close to the steering column above) so I cut about 10mm out of the cylinder and then welded the tread back on.
The weld marks above are from the reinforcing plates I put the outside of the fire wall, just to give the fire wall some more strength.
Dude, I am impressed. I've been bitching about the difficulty of this build since I failed at it in 2007. You're actually doing it, albeit minus the M54, but IMO you've choosen a fine motor to keep the car balanced. Kick ass. I'll be following this.
Michael Rose
'91 Porsche 964
'00 Dodge Durango
'13 Honda Pilot
At one point I looked at putting a V8 out of a 7 series, but decided that would just ruin the car. M44 with twin side drafts would give it an old school look.
Tonight I moved inside the car. I am going install the seats out of the E36 ti, firstly I had to cut out the factory 2002 seat mounts and then install some more suited to the E36 seats
