Transforming a 2002 into a E36- The build
rot62
This is copied across from another site, I hope it reads ok
I brought this car some time ago. It sat in a friends barn until a few years ago when I finally decided to get it going again. Due to the fact it had been parked up for so long the first things I had to do were get the carbs recond, new water pump and replace all the brake hoses. The last wof it failed on a rust hole in the boot and therefore got parked up again. I have since then repaired the rust in the boot and replaced the radiator.
  • Replies 148
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Due the to the age of this car parts are getting scarce. I have wanted to change the diff for a long time but have not be able to source the ratio I what. So therefore a few months ago I brought a crashed E36 318 compact as a donor car. A week ago I started to change the rear subframe for the 318ti
The E36 sub frame was about 50mm wider than the 2002, and it needed to come forward 25mm. So I remounted the front bolts and gave the sub frame some clearance. I am getting some plates made that will go from this mount to the floor pan (some extra bracing)
